Best Value Rack Air Removal Unit 100-240V
Quicklinx: 7RDZWS00 Mfr#: ACF400
High-density equipment creates an environment where traditional air distribution methods are often not effective. Densely packed enclosures can cause IT equipment to overheat, resulting in downtime. The Rack Air Removal Unit SX captures exhaust heat, returns the warm air to the plenum and eliminates hot spots from the data center. Through automatic fan speed control based upon temperature, the fans will self-adjust for optimal performance. With a unit-mounted LCD display, users can view temperatures at the rack, monitor alarm conditions and adjust unit set points. The integrated network management card allows for remote monitoring and control of the Rack Air Removal Unit SX. This space-saving solution mounts to the back of either the Netshelter SX or VX enclosure, requiring zero U space.
  • LCD display
    Alpha-Numeric Display which displays system parameters and alarms
  • Temperature monitoring
    Changes in temperature are reported via the user interface or e-mail
  • Increased capacity
    Higher rate of heat removal allows more equipment to be installed in each rack
  • Ducted Exhaust System
    Removes hot air from the data center to prevent re-circulation and eliminate air mixing
  • Fan guards
    A safety measure that provides protection from the fan opening by covering the inlet
  • Dual A-B Power Inputs
    Draws power from the UPS for power protection with dual feeds for redundancy
  • Fault-tolerant fan system
    In the event of a fan failure, the remaining fan(s) will continue to operate
  • Field replaceable components
    Fans and electronics module can be readily replaced without uninstalling the unit
  • Adjustable mounting frame
    The frame can mount on Netshelter SX or VX enclosures and extends to accommodate 42U, 47U or 48U rack heights
APC - rack fan kit
Rack fan kit
P/N: AP7950B, AR3106SP, AR9300SP, AR9300SP-R, AR9307SP, AR9307SP-R, NBPD0160A, NBWL0355A, NBWL0356A, SMC15002U-BR, SMC1500I2U-BR, SMC1500I-2UC, SMT3000I2U-BR, SMX2000LVNCUS, SMX2000LVUS, SMX3000HV-BR, SMX3000HVTUS, SMX3000LV2U-BR, SMX3000LVUS, SRT1000RMXLI, SRT1000RMXLI-NC, SRT1500RMXLA-NC
Rack fan kit
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC2513, AP5017, AP5602, AP5606, AP5607, AP5616, AP7555, AP7562J, AP7701X298, AP7841, AP7852, AP7854, AP7857, AP7867, AP7894, AP7911, AP7940, AP7941, AP7950, AP7950B, AP7951, AP7952, AP7953, AP7954, AP7957, AP7961, AP7961X364, AP7991, AP92200, AP9290, AP9571, AR2900, AR2901, AR3000, AR3100, AR3100CTO, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100-TU, AR3100W, AR3100X487, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3106SP, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3810, AR3812, AR7007, AR9300SP, AR9300SP-R, AR9307SP, AR9307SP-R, DLA1500RM2U, NBPD0160A, NBPD0171, NBWL0355A, NBWL0356A, SBATTBLK, SC250RM1U, SC250RMI1U, SMC15002U-BR, SMC1500I-2U, SMC1500I2U-BR, SMC1500I-2UC, SMT3000I2U-BR, SMX2000LV, SMX2000LVNC, SMX2000LVNCUS, SMX2000LVUS, SMX2200R2HVNC, SMX3000HV-BR, SMX3000HVT, SMX3000HVTUS, SMX3000LV, SMX3000LV2U-BR, SMX3000LVUS, SRT1000RMXLA, SRT1000RMXLA-NC, SRT1000RMXLI, SRT1000RMXLI-NC, SRT1500RMXLA, SRT1500RMXLA-NC, SU1400RMXLB3U, SU3000RMJ3U3W, SU3000RMJ3UOS3, SU5000R5TBXFMR, SUA1500R2X138, SUA2200R2X106, SUA2200R2X147, SUA2200R3XLNETPKG, SUA2200RMXL3U, SUA2200RMXLI3U, SUA3000R2IX38, SUA3000R2X180, SUA3000R2X428, SUA3000R3XLNETPKG, SUA3000RMXL3U, SUA3000RMXL3U-BR, SUA750R2X122, SUA750R2X338, SURT10000RMXLT, SURT10000RMXLT-2TF5, SURT3000RMXLI, SURT3000RMXLT, SURT3000RMXLT-1TF5, SURT5000RMXLI, SURT5000RMXLT, SURT5000RMXLT-1TF5, SURT5000XLIX438, SURT6000RMXLT, SURT6000RMXLT-1TF5, SURT7500RMXLI, SURT7500RMXLT, SURT7500RMXLT-1TF5, SURT7500XLJ-2TF4, SURT8000RMXLT, SURT8000RMXLT-1TF5, SURTA1500RMXL, SURTA2000RMXL, SURTA2000RMXL2U, SURTA3000RMXL, SURTD3000RMXLT, SURTD3000RMXLT-1TF5, SURTD5000RMXLT, SURTD5000RMXLT-1TF5, SYH2K6RMJ-TF3
