Graphics processing has become an essential ingredient to the modern PC. Nowadays, Palit simply demands more from the PCs to deliver gorgeous graphics, fantastic video, crisp responsive photo editing. The Palit GeForce 210 graphics card brings impressive graphics processing power to your PC at an affordable price.
- Designed to work perfectly with the new PCI Express 2.0 bus architecture, offering a future-proofing bridge to tomorrow's most bandwidth-hungry games and 3D applications by maximizing the 5GT/s PCI Express 2.0 bandwidth.
- World's first DirectX® 10.1 GPU with full Shader Model 4.1
- Windows 7 is the next generation operating system that will mark a dramatic improvement in the way the OS takes advantage of the graphics processing unit (GPU) to provide a more compelling user experience.
- The combination of high-definition video decode acceleration and post-processing that delivers unprecedented picture clarity, smooth video, accurate color, and precise image scaling for movies and video.
- CUDA™ technology unlocks the power of the GPU's processor cores to accelerate the most demanding system tasks such as video transcoding, physics simulation, ray tracing, and more, delivering incredible performance improvements over traditional CPUs.
Specification
- Memory Amount 1024MB
- DRAM Type DDR3
- NVIDIA PureVideo HD Technology
- NVIDIA CUDA Technology
- Microsoft DirectX 10.1
- OpenGL 3.3
- Certified for Windows 7
- Maximum Digital Resolution 2560x1600
- Maximum VGA Resolution 2048x1536
- Dual-Link DVI Yes
- VGA
- HDCP
- HDMI Yes
- PCB Width 145mm x 69mm
- Graphics Card Power (W) 30.5 W
- Minimum Recommended System Power (W) 300 W
- Accessory Manual, CD Driver
- Palit GeForce 210 - graphics card - GF 210 - 1 GB
- Graphics card
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- NVIDIA GeForce 210
- Memory
- 1 GB DDR3
- Memory Interface
- 64-bit
- DVI-I (dual link) , HDMI , VGA
- API Supported
- OpenGL 3.2, DirectX 10.1
- Microsoft Certification
- Compatible with Windows 7
- Graphics card
- Bus Type
- Graphics Engine
- API Supported
- Nvidia CUDA technology, Nvidia PureVideo HD technology, HDCP
- Size
- 1 GB
- Technology
- DDR3 SDRAM
- Bus Width
- 64-bit
- OS Required
- Microsoft Windows Vista / XP / 7
- Required Power Supply
- 300 W
