Cables Direct Best Value 24 Port Cat 6 Punch Down Patch Panel
Quicklinx: 7YLLWS00 Mfr#: UT-8824
The UT-8824 is a 24 port 1U rack mountable CAT6 patch panel which is a great solution for network and cable management. The UT-8824 offers a clearly labelled, neat and effective CAT6 pass through panel which is ideal for the heart of any medium sized network.
Specification
  • Meets the TIA/EIA-568-B.2-1 Category 6 Channel Testing Performance requirements.
  • Support T568 A&B wiring & Easy installation.
  • Dual IDC connector can accept 22-26 AWG solid and stranded UTP cables.
  • 24 Port (1U)
  • Compatible with 110 or Krone Tools.
  • Backwards compatible with Category 3, 5 & 5E.
  • 19" rack mountable.
Cables Direct UT-8824 - patch panel - 1U - 19"
Patch panel - CAT 6 - RJ-45 X 24
Port Qty
24 ports
Height (Rack Units)
1U
Patch panel - CAT 6
Height (Rack Units)
1U
Cabling & Wiring
Port Qty
24 ports
Termination Type
110 type termination, LSA (Krone)
Unshielded twisted pair (UTP)
Connector Provided
24 x RJ-45 female
Rack Size
19"
