Your basket is empty
BenQ MX501 - DLP Projector - 3D Ready - 2700 ANSI lumens - XGA (1024 x 768) - 4:3
Quicklinx: 7QBDWS00 Mfr#: 9H.J5377.14E
  • Compatible with Windows 7
The MX501 makes the perfect projector choice for your everyday life - in business, education, even at home. Featuring an impressive brightness of 2700 ANSI lumens, a high contrast ratio of 4000:1 and a XGA resolution, the MX501 offers a stunning full-screen presentation with the finest details regardless of the low ambient light level.
DLP Projector
3D Technology
Built-in Devices
Speaker
28.7 cm x 23.2 cm x 10 cm
2.5 kg
Image Brightness
2700 ANSI lumens
Image Contrast Ratio
4000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
220 Watt
Bulb life cycle
4500 hour(s) / 6000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video ( NTSC, SECAM, PAL )
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Video Output
RGB
Audio Output
Speaker(s) - integrated
Sound Output Mode
Mono 2 Watt
Input Device
Remote control
AC 120/230 V ( 50/60 Hz )
270 Watt
2 year warranty
DLP Projector
3D Technology
Built-in Devices
Speaker
28.7 cm
23.2 cm
10 cm
2.5 kg
Projector / Panel
Image Brightness
2700 ANSI lumens
4000:1
Image Size
61 cm - 762 cm
Throw Ratio
1.86 - 2.04:1
Digital Zoom Factor
2x
Resolution
XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 99 kHz
Bulb type
220 Watt
Bulb life cycle
Controls / Adjustments
Keystone correction
OSD Languages
Danish, Hindi, Hungarian, Czech, Croatian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Japanese, Korean
Freeze frame, Closed Caption, wall colour correction, BrilliantColor, DLP 3D Ready
Projector Lens System
Focus Type
Manual
Lens Aperture
F/2.56-2.8
Zoom Type
Manual
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
Analogue Video Format
NTSC, SECAM, PAL
Analogue video Signal
Video Modes
Video Output
Analogue Video Signal
RGB
Audio Output
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speaker(s)
1 x mixed channel
Input Device
Remote control - external - wireless
2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 PIN mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x RGB output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) ( management ) , 1 x USB - mini-USB Type B , 1 x audio line-out - mini-phone stereo 3.5 mm
1 x VGA cable
Security Features
Password protection
Power supply - internal
270 Watt
Power Consumption Operational ( Standby )
1 Watt
1 year warranty
Service & Support Details
Limited warranty - lamp - 1 year
Sound Emission
33 dB
27 dB
