Whether you're catching up on the latest show on the Internet or viewing documents, the BenQ GL2450HM LED monitor is the perfect choice for you in style! Featuring a dynamic ratio of 12000000: 1, speakers, response time of 2 ms and DVI and HDMI connector, this 24" 16:9 LED monitor delivers you the audiovisual enjoyment.
Brilliant image quality
LED backlighting offers significant advantages over the CCFL technology used in older LCD monitors. These advantages encompass not only performance metrics such as higher dynamic contrast, no light leakage and flicker-free, but also environmental factors, like a manufacturing process and disposal that produces fewer pollutants. -
12000000: 1 ultra high dynamic contrast for depth and definition
The GL2450HM comes with an ultra-high dynamic contrast ratio of 12000000: 1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games. -
Perfecting your audiovisual enjoyment with speakers
Whether you're listening to music or watching your favorite film, simply turn on the speakers to experience the audiovisual fun! -
HDMI multimedia interface
The HDMI high-speed multimedia interface makes the monitor incredibly convenient to use - you can enjoy digital entertainment effortlessly even with additional multimedia equipment in the future. -
Superior response time
Enjoy high dynamic videos without ghosting or other artifacts with 2 ms GTG response time. -
Senseye technology
Experience the truest colors of the world with the BenQ Senseye Human Vision technology. With the help of its six proprietary calibration techniques, Senseye 3 delivers only the best viewing quality in each of its six pre-set viewing modes - standard, movie, game, photo, sRGB, and eco - with the eco mode especially designed to save power and money. -
Save energy to save up
Energy-efficient LED panel provides greater power saving by 14.3% and with the help of eco mode, you can save up to 39.3%. -
ENERGY STAR qualified
The GL2450HM complies with the requirement of ENERGY STAR program for computer monitors. You can enjoy saving energy and money as well as keeping the Earth lookin' great!
- BenQ GL2450HM - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class B
- Energy Consumption per Year
- 39 kWh
- Power Consumption (On mode)
- 27 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Response Time
- 2 ms (gray-to-gray), 5 ms (typical)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- HDMI, DVI-D, VGA
- Speakers
- Integrated
- Tilt
- Glossy black
- 57.9 cm x 17.9 cm x 43.6 cm
- 4.1 kg
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- Display Type
- Energy Class
- Class B
- 39 kWh
- Diagonal Size
- 24"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Response Time
- Vertical Refresh Rate
- 76 Hz
- Horizontal Refresh Rate
- 83 kHz
- Video Bandwidth
- 205 MHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Tilt, colour temperature
- HDCP, Eco-Mode, Advanced Motion Accelerator (AMA) technology, Senseye Human Vision Technology, Senseye 3 Technology
- Glossy black
- 4.1 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- DVI-D , HDMI , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable - VGA to VGA , 1 x audio cable - 3.5 mm to 3.5 mm
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- 27 W
- Power Consumption (Typical)
- 42 Watt
- Power Consumption Stand by / Sleep
- 0.3 Watt
- 0.3 Watt
- On / Off Switch
- No
Sustainability Information
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
