Whether you're catching up on the show on the Internet or viewing documents, the BenQ GL2023A LED monitor is the perfect choice for you! Featuring a dynamic contrast ratio of 12M: 1, response time of 5 ms, and BenQ's exclusive Senseye technology, this 19.5"W 16:9 LED monitor delivers you the visual enjoyment with best value.
Brilliant image quality LED leads the way
LED backlighting offers significant advantages over the CCFL technology used in older LED monitors. These advantages encompass not only performance metrics such as higher dynamic contrast, no light leakage and flicker-free, but also environmental factors, like a manufacturing process and disposal that produces fewer pollutants. -
12M: 1 ultra high dynamic contrast for depth and definition
The GL2023A comes with an ultra-high dynamic contrast ratio of 12M:1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games. -
Superior response time
Enjoy high dynamic videos without ghosting or other artifacts with 5 ms response time. -
Senseye technology
Experience the truest colors of the world with the BenQ Senseye Human Vision technology. With the help of its six proprietary calibration techniques, Senseye 3 delivers only the best viewing quality in each of its six pre-set viewing modes -VStandard, movie, game, photo, sRGB, and Eco -V with the Eco Mode especially designed to save power and money. -
ENERGY STAR qualified
The GL2023A complies with the requirement of ENERGY STAR Program for computer monitors. Now you can enjoy saving energy and money as well as keeping the Earth lookin' great!
- BenQ GL2023A - LED monitor - 19.5"
- LED-backlit LCD monitor - 19.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900
- Pixel Pitch
- 0.27 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1 / 12000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- VGA
- Tilt
- Voltage
- AC 120/230 V
- Glossy black
- 47.7 cm x 16.5 cm x 35.9 cm
- 2.9 kg
- Display Type
- Diagonal Size
- 19.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900
- Pixel Pitch
- 0.27 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Colour temperature
- Senseye Human Vision Technology, Senseye 3 Technology
- Glossy black
- 47.7 cm x 16.5 cm x 35.9 cm - with stand
- 2.9 kg
- VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- AC 120/230 V
- Power Consumption (Typical)
- 15 Watt
- Power Consumption Stand by / Sleep
- 0.3 Watt
- OS Required
- Microsoft Windows 7, Windows 8
