Your basket is empty
BenQ G950A  LCD monitor  18.5"  1366 x 768   5 ms  VGA  glossy black
Quicklinx: 832GWS00 Mfr#: G950A
Diagonal Size: 18.5in
Max Resolution: 1366 x 768
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15)
  • Compatible with Windows 7
5 on order, no confirmed delivery date
£54.40 ex VAT
£65.28 inc VAT
Built for your living space and work station, the BenQ G950A features a 18.5W" LCD panel with a dynamic contrast ratio of 50,000:1 , 16:9 100% dot-to-dot image quality, and BenQ's exclusive Senseye Technology to offer you the best viewing quality at all times. It's your best value choice that will keep things lookin' great!
BenQ G950A - LCD monitor - 18.5"
LCD monitor - 18.5"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
1366 x 768
Pixel Pitch
0.3 mm
Brightness
200 cd/m2
Contrast Ratio
700:1 / 50000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
Glossy black
46 cm x 16.4 cm x 36.2 cm
3 kg
Microsoft Certification
Display Type
LCD monitor / TFT active matrix
Diagonal Size
18.5"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
1366 x 768
Pixel Pitch
0.3 mm
Brightness
200 cd/m2
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
76 Hz
Horizontal Refresh Rate
83 kHz
Video Bandwidth
110 MHz
Controls & Adjustments
Colour temperature
Senseye Human Vision Technology, Senseye 3 Technology
Glossy black
3 kg
VGA
Mechanical
Tilt
Tilt Angle
-5/+15
Flat Panel Mount Interface
100 x 100 mm
Wall mountable, K-lock security slot
Power Supply
Internal
24 Watt
Response Time: 5ms
Speakers: None
Colour: Glossy black
Brand: BenQ
Price Range Ex VAT: 50 - 100
