With ergonomic design for work comfort and economic value of cost-effectiveness, the BL902TM is designed to fit your working needs. It features 130mm HAS, around-the-clock smart reminder, anti-glare display and speakers. Adopting recyclable plastic materials and greener packaging, this monitor is built to keep the Earth lookin' great!
World's leading expert in LED monitors
BenQ - the world's leading LED monitor brand - has put together the perfect business solution. BL902TM monitor comes with LED backlight technology to offer economic value of cost-effectiveness and ecological considerations for protecting environment. -
Anti-glare display
A glare panel - whether it's caused by a direct or reflected light source - makes it a challenge for office workers to see clearly without straining their eyes. The BenQ BL series LED monitors feature an anti-glare, matt-finish display to keep distracting reflections to a minimum, so office workers can work through their day-to-day tasks with well-improved efficiency - squint-free! -
Ultra-flexible height adjustment system (HAS)
Tailor the height, tilt, pivot, stroke and swivel adjustment of each monitor to perfectly fit individual users! BenQ's ultra-flexible height adjustment system (HAS) offers an extensive range of monitor adjustments to keep office workers of all shapes and sizes comfortable and fit for every work situation. -
Energy efficient and money saving
The BenQ BL902TM is built with the LED backlight technology to cut down power consumption. LED backlighting is also known for its highly durable and stable performance on brightness and color presentation - which means an extended usable lifespan for your business solutions. -
Built-in speakers
BenQ has added built-in speakers to the BL902TM to boost the appeal of your business solutions! Not having to buy separate sound systems means you get to save up more money! -
Recyclable plastic materials
Built to successfully minimize waste and environmentally harmful pollution, the BenQ BL902TM monitors are coating-free and 100% recyclable - with 65% of the monitor frame made of recycled plastics. -
Greener packaging
The BenQ BL902TM comes with an extra green packaging for easier recycling. All materials used for packaging are EPS-free - with all PVC or foamed plastics replaced with recyclable paper cushion. Moreover, recycled paper is used for 80% packing to save forests. -
Ultra-high dynamic contrast ratio
An amazing 12,000,000:1 dynamic contrast ratio adds color depth and definition to darkened and complex visuals. Any image from the brightest white to the darkest black is perfectly rendered to deliver the most incredible picture performance. -
Superior response time
With a speedy 5ms response time, even highly dynamic video is rendered with smooth, fluid motion without ghosting or other artifacts to distract your view.
- BenQ BL902TM - BL Series - LED monitor - 19"
- LED-backlit LCD monitor - 19"
- Stereo speakers
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.294 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Response Time
- 5 ms
- Input Connectors
- DVI-D, VGA
- Height, swivel, tilt
- Black
- 41.9 cm x 22.3 cm x 43.2 cm
- 5.1 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- Display Type
- Diagonal Size
- 19"
- Built-in Devices
- Stereo speakers
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.294 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Colour temperature
- HDCP, anti-glare, Senseye 3 Technology
- Black
- 41.9 cm x 22.3 cm x 43.2 cm - with stand
- 5.1 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1 Watt
- VGA , DVI-D , Headphones , Audio line-in
Mechanical
- Tilt Angle
- 25
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), wall mountable
- Cables Included
- 1 x audio cable , 1 x VGA cable , 1 x DVI cable
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Power Consumption (Typical)
- 25.8 Watt
- Power Consumption Stand by / Sleep
- 0.3 Watt
Sustainability Information
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
