Belkin USB A-B device cable 1.8M
Customer rating: 5.0* (Write a review)
Quicklinx: QV9WS00 Mfr#: F3U133B06
Now you can attach all your high-speed USB devices to your computer and enjoy error-free transmissions. The Belkin Pro Series Hi-Speed USB 2.0 Cable is the perfect solution for connecting your USB printer, scanner, hard drive, and other equipment. It supports up to 127 devices on a daisy-chain configuration and transmits data at up to 480Mbps. Gold-plated copper contacts provide maximum conductivity and minimize data loss, and hot-pluggable design assures fast connectivity.
Belkin PRO Series - USB cable - USB to USB Type B - 1.8 m
USB cable
Shielded
Molded
Length
1.8 m
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type B - male
USB / USB 2.0
ExpressBus 7-port, Plus; USB Direct Connect
USB cable
Shielded
American Wire Gauge (AWG)
26
Plated Connector
Gold
Molded
Length
1.8 m
Connector
USB / USB 2.0
Belkin ExpressBus 7-port, Plus , Belkin USB Direct Connect
Customer reviews
Write a review for the Belkin USB A-B device cable 1.8M here!
USB A-B
Reviewed by Anonymous Review Posted 13/07/2004
Good cable, it works.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
