Your basket is empty
Belkin Cat6 UTP Snagless Patch Cable Grey 2m
Quicklinx: 18K6WS00 Mfr#: A3L980B02M-S
Length: 2m
4 in stock
£3.39 ex VAT
£4.06 inc VAT
Upgrade your network with a CAT6 Snagless Networking Cable from Belkin and enjoy clean, clear transmissions. Now you can replace CAT5 cables that don't support 100BASE-T or Gigabit Ethernet and improve the return loss in your current network by 40 percent. Engineered with 50-micron gold-plated connectors to ensure clear transmissions, and snagless molds to protect the RJ45 tabs from damage during installation, this cable meets and exceeds the performance requirements of Category 6.
Belkin High Performance patch cable - 2 m
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568A
Moulded, snagless , gold-plated connectors
Length
2 m
Connector(s)
1 x RJ-45 - male
Connector(s) (Other Side)
1 x RJ-45 - male
Omniview SMB 1x16 KVM-over-IP Switch, SMB 1x8 KVM-over-IP Switch; OmniView SMB CAT5 KVM Switch
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568A
Length
2 m
Connector(s)
1 x RJ-45 - male
1 x RJ-45 - male
Belkin Omniview SMB 1x16 KVM-over-IP Switch, SMB 1x8 KVM-over-IP Switch , Belkin OmniView SMB CAT5 KVM Switch
Length: 2m
Colour: Grey
Brand: Belkin
Price Range Ex VAT: 0 - 50
