Belkin 8-Way Max SRS SurgeMaster Tel 4m
Quicklinx: 2D3ZWS00 Mfr#: F9M820UK4M
Power surges and lightning strikes are not the only things that can damage your home electronic equipment. Simply switching appliances on and off can create electrical imbalances that cause cumulative, permanent damage to your computers, peripherals and electronic equipment. Decades of research and power protection development have led to the release of this breakthrough SurgeMaster series. Using advanced design elements and top-quality construction as well as superior circuitry, the SurgeMaster offers the most complete protection from power surges, AC contamination and spikes available. As the leading developer of surge protection solutions, Belkin engineers and rigorously tests all its products to ensure your equipment will be safe from harmful electrical imbalances, whatever your configuration and whichever grade you choose. The Belkin SurgeMaster is your premiere solution for clean, safe power and the industry's best in construction, ratings and safety standards. Over 38 million Belkin SurgeMaster units are protecting consumer electronics worldwide!
Belkin SurgeMaster Maximum Series - surge protector
Surge protector - external
English / United Kingdom
Input Voltage
AC 250 V
Input Connectors
1 x power BS 1363
Output connectors
8 x power BS 1363
White
White
Input Voltage
AC 250 V
Frequency Required
50 Hz
Input Connectors
1 x power BS 1363
8 x power BS 1363
Dataline Surge Protection
Phone line - RJ-11 - 1 input line / 2 output lines
Surge Suppression
Surge Response Time
1 ns
Surge Energy Rating
2700 Joules
EMI/RFI Noise Filtration
65 dB
Max Spike Voltage
6000 V
Circuit Protection
Circuit breaker
Power cable - integrated - 4 m
Equipment Protection Value
175000 British Pounds
Limited warranty - lifetime
