Pill XL is bigger, louder, and has a built-in handle so you can still pick up and go. This speaker is loud enough for a big room or your backyard BBQ. It connects to any Bluetooth-enabled device so you're free to let the music move you. With the Pill family's updated features, you can amplify or stereo your music with other Pill XLs.
Totally portable
You're good to take your music everywhere. Despite its bigger size, Pill XL is still lightweight and has a built-in handle for extra portability. The Pill XL frees you to roam, which means you'll always have high quality sound near or far. -
Tap to pair
Pairing is easy. Just tap your phone to Pill XL to create an instant connection. Once connected, you can change tracks from your phone, your laptop, or any other Bluetooth-enabled device from up to 30 feet away. -
Tap to amplify
Two Pill XLs will bring down any house. Sync two Pill XLs by tapping them together to play the same song. -
Tap to stereo
Just tap two Pill XLs together twice to make one Pill XL the left output and the other the right. Now you can bring the concert home with you. -
Visible fuel gauge
Dead batteries can kill your vibe in a flash. Pill XL has a visible battery fuel gauge so you'll always know how much juice is left. Its rechargeable battery gives you 15 hours of continuous play and will automatically shut off after ten minutes of no signal detection to save power. -
Charge out
Keep the music going. Now you can charge your phone or external music device with extra juice from the Pill XL.
- Beats Pill XL - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Speaker Type
- Active
- Amplifier
- Integrated
- Bluetooth, NFC
- Titanium
- Power Options
- USB charging, auto power on/off
- Battery
- Speaker battery rechargeable - Lithium Ion
- 33.8 cm x 10.4 cm x 10.4 cm
- 1.49 kg
- Product Type
- Hands-Free Function
- Enclosure Colour
- Titanium
Speaker System
- Speaker Type
- Active
- Amplifier
- Integrated
- Bluetooth, Near Field Communication (NFC)
- Transmission Range
- 10 m
- Controls
- Power on/off, volume
- Additional Features
- Integrated carrying handle, smartphone remote controlled, LED indicators, Beats Bond pairing
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm) , Audio line-out (mini-phone stereo 3.5 mm) , DC power output (4 PIN USB Type A)
- Included Accessories
- AC power adaptor, audio cable
- Power Source
- Battery
- Options
- Rechargeable - Lithium Ion
- Run Time (Up To)
- 15 hour(s)
- 33.8 cm
- 10.4 cm
- 10.4 cm
- 1.49 kg
