The AVer VC520 breaks the mold of traditional, expensive and complicated video conferencing systems that require a network administrator to operate. The VC520 is an affordable USB PTZ video collaboration camera optimized to deliver an exceptional video and audio communication experience. Gone are the headaches of having to modify complicated network firewalls to make a video call. With the VC520, video conferencing is now as simple as plugging in a USB cable.
12x optical zoom with PTZ
With this fast and smooth 12x optical zoom camera, the VC520's multi-element, multi-coating auto-focus optics and 12x true optical zoom deliver rapid and smooth pan, tilt and zoom-in performance to capture small details with absolute clarity at every focal length. -
Full HD 1080p video
With Full HD 1080p video built into the VC520, you will enjoy high resolution available for your video conferencing and video collaboration calls. -
Daisy-chain speakerphone system
The days of having to crowd around a single speakerphone are now over! The VC520 includes a full duplex speakerphone and gives you the ability to daisy-chain an additional speakerphone. Each speakerphone can cover a 30 ft diameter, so now you can effectively capture audio throughout the entire room. -
10 camera presets
Having only one camera preset can be extremely limiting. The VC520 allows you to customize your meetings by storing up to 10 PTZ presets. Each preset can be easily accessed with one touch of the remote, saving you time and providing flexibility to swiftly move to predetermined locations in the conference room. -
Full duplex microphone array
The VC520 microphone array delivers full duplex audio. Full duplex audio enables all sites the ability to speak without the worry of being cut off mid-sentence and ensures that the entire conversation will be heard by all participants on the call. Regardless of the room size or configuration, the VC520's superior echo cancellation and noise suppression technology reduces hollow-sounding audio, echo and background noise resulting in crystal clear audio communication.
- AVer VC520 - conference camera
- Conference camera - pan / tilt / zoom
- 18 cm x 14 cm x 18.2 cm
- 1.5 kg
- Connectivity Technology
- Wired
- Camera
- Optical Zoom
- 12 x
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 60 frames per second
- Video Modes
- 720p, 1080p
- Optical Sensor Type
- CMOS - 1/2.8" - 2 MP
- Minimum Illumination
- 1 lux F1.6 - 50 IRE
- Focal Length
- 3.9 mm - 46.1 mm
- Focus Adjustment
- Automatic
- Lens Iris
- F/1.8-2.8
- Panning Range (degree)
- -130 to +130
- Tilting Range (degree)
- -25 to +90
- USB 2.0
- Cables Included
- 1 - USB cable - external , 2 - audio cable - external , 1 - video cable - external
- Manual white balance, Backlight Compensation (BLC), progressive scanning, security lock slot (cable lock sold separately), auto white balance, 10 preset positions
- 3-year warranty
- Environmental Parameters (operating)
- 0 °C - 40 °C; 35 - 90% (non-condensing) relative humidity
- Conference camera
- Wired
- 18 cm
- 14 cm
- 18.2 cm
- 1.5 kg
Camera
- Colour - pan / tilt / zoom
- Digital Video Format
- MJPEG, H.264
- Max Digital Video Resolution
- 1920 x 1080
- Video Modes
- 720p, 1080p
- Frame Rate (max)
Image Sensor
- 2 MP CMOS 1/2.8"
Lens Construction
- Optical Zoom
- 12 x
- Focal Length
- 3.9 mm - 46.1 mm
- Lens Iris
- F/1.8-2.8
- Focus Adjustment
- Automatic
- Horizontal Field of View (degree)
- 6.3 - 82
Panning
- Range (degree)
- -130 to +130
- Speed (degree/sec)
- Up to 0.45
Tilting
- Range (degree)
- -25 to +90
- Up to 0.4
- Computer Interface
- USB 2.0
- Ports
- USB 2.0
- Included Accessories
- Remote control, mounting kit, speakerphone, USB hub
- Cables Included
- 1 x USB cable - external , 2 x audio cable - external , 1 x video cable - external
- Plug and Play
- Power Device
- Power adapter AC 120/230 V
- OS Required
- Apple MacOS X 10.7 or later, Microsoft Windows 7 / 8 / 8.1
- System Requirements Details
- Core 2 Duo - 2.4 GHz - RAM 2 GB
- Limited warranty - 3 years , Limited warranty - replacement - 1 year
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 35 - 90% (non-condensing)
