With its half-space unidirectional polar pattern, low-profile design, and outstanding sound quality, the PRO 44 is ideal for conference tables, podiums, lecterns and other installed-sound uses. This versatile boundary microphone's self-contained electronics eliminate the need for external power modules. The PRO 44 is equipped with a wide-range condenser element with low-mass diaphragm for superior performance.
- Audio-Technica PRO 44 - microphone
- Product Type
- Microphone
- Recommended Use
- Voice recorder
- Microphone
- External - on-cable
- Microphone Technology
- Electret condenser
- Product Type
- Microphone
- 73 mm
- 90.5 mm
- 15 mm
- 67 g
- Recommended Use
- Voice recorder
Microphone
- On-cable
- Connectivity Technology
- Wired
- Impedance
- 100 Ohm
- Signal-To-Noise Ratio
- 66 dB
