Asus Z170I PRO GAMING Intel Z170 LGA 1151
Quicklinx: BJ0JWS00 Mfr#: Z170I PRO GAMING
  • IEEE 802.11n
Be the best on the battlefield with Z170I Pro Gaming's truly immersive SupremeFX audio and experience sound so alive with realism that it hands you the vital competitive edge needed to win. With near-lossless delivery and exclusive Sonic Radar II technology to pinpoint battlefield enemies before they spot you, SupremeFX sounds stupendous - and puts both your ears and frags in front of everyone else!
  • Shielded audio, superior sound
    ASUS-exclusive SupremeFX technology delivers high-fidelity, near-lossless audio no matter how frantic your game becomes. The purity and stability of the remarkable 115dB signal-to-noise ratio (SNR) is assured, with a shielded design, electromagnetic-interference (EMI) cover and voltage-protected 5V power supply. Supreme FX's superior components, including the trusted Realtek ALC1150 codec, maximize acoustic performance and eliminate interference - so you hear only the very best from your gaming headset or speakers!
  • Scan and detect to dominate!
    Sonic Radar II displays a stealthy overlay that shows what your opponents and teammates are up to on the battlefield, all managed via a simple control panel and customizable game list. See the direction and origin of key in-game sounds, and practice your enemy-pinpointing skill, plus Audio Enhancement technology clarifies every last sound - so you hear the distant sound of enemy footsteps and become the hunter, not the hunted!
  • Top-speed protected networking
    Only the quickest shot survive, so Z170I Pro Gaming banishes lag - letting you annihilate your foes as fast as your trigger finger!
  • Intel Gigabit Ethernet
    More throughput, less CPU usage and great gaming experiencesFeaturing the very latest Intel Ethernet (I219-V) for faster, smoother gaming - always. Intel's LAN has the serious double advantage of reducing CPU overhead and offering exceptionally high TCP and UDP throughput. This significantly reduces the processor's workload, so there's more power for your game and your gameplay.
  • Performance level up
    Maxed-out performance means maximum gaming thrills, and with ASUS-exclusive Pro Clock technology, AI Suite 3's dashboard-style control panel and RAMCache you'll fine-tune almost every aspect of your Z170I Pro Gaming-based system. Get the best balance between performance, cooling, stability, efficiency and aesthetics - all via a simple and intuitive interface.
  • Speed your game loads
    Uniquely-intelligent technology that effectively caches an entire storage device so that favorite games and apps launch at breakneck speeds, getting to work the moment it's activated. RAMCache turns milliseconds into microseconds to boost game-load times to stratospheric levels!
ASUS Z170I PRO GAMING - motherboard - mini ITX - LGA1151 Socket - Z170
Motherboard - mini ITX
Chipset Type
Intel Z170
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
4 x SATA-600 (RAID), 1 x SATA Express port, 1 x M.2
USB / FireWire Ports
2 x USB 3.1 + 4 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 2 x USB 2.0 via headers)
Max Allocated RAM Size
1024 MB
Audio
HD Audio (8-channel)
LAN
Bluetooth, Gigabit Ethernet, 802.11a/b/g/n/ac
Chipset Type
Intel Z170
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR4
Bus Clock
2133 MHz, 2800 MHz (O.C.), 2933 MHz (O.C.), 2666 MHz (O.C.), 2600 MHz (O.C.), 2400 MHz (O.C.), 3000 MHz (O.C.), 3100 MHz (O.C.), 3200 MHz (O.C.), 3400 MHz (O.C.), 3333 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1024 MB
Audio
Audio Codec
SupremeFX
High Definition Audio
LAN
Network Controller
Intel I219V
Network Interfaces
Expansion Slots
1 x CPU , 2 x DIMM 288-pin , 1 x PCIe 3.0 x16
Storage Interfaces
SATA-600 / PCIe 3.0 -connectors: 4 x 7pin SATA, 1 x M.2, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5
RAID Features
Intel Smart Response Technology
1 x HDMI , 1 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.1 , 4 x USB 3.0 , 2 x USB 2.0 , 1 x PS/2 keyboard / mouse , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x TOSLINK
Internal Interfaces
2 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support
Sleep / Wake Up
Wake on LAN (WOL), wake on PME
Hardware Features
Jack retasking, ASUS Q-Design, ESD Guards, Q-DIMM, GPU Boost, ASUS EZ DIY, Q-LED, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, ASUS TurboV, Intel Turbo Boost Technology 2.0, ASUS TPU (TurboV Processing Unit), ASUS DIGI+ VRM, Intel Clear Video HD Technology, Fanless Design Heatsink, SupremeFX Shielding technology, ASUS Wi-Fi GO!, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, Nichicon High-end Audio Capacitors, Disk Unlocker, ASUS Enhanced DRAM Overcurrent Protection, Preboot eXecution Environment (PXE), EMI shielding cover, ASUS Stainless Steel Back I/O, ASUS Fan Xpert 2+, Dual Intelligent Processors 5, LANGuard, Sonic Radar II, USB 3.1 Boost, ASUS PRO Clock Technology, GameFirst IV
Cable labels, 1 x M.2 screw, I/O back cover
4 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS Auto Tuning, ASUS AI Charger+, ASUS AI Suite III, ASUS EZ Update, ASUS Turbo App, Antivirus (OEM version), Media Streamer, ASUS RAMCache
Plug and Play, ACPI 5.0
17 cm
17 cm
