ASUS 4G-N12 is no ordinary Wi-Fi router. Just insert a 4G/LTE SIM card and its built-in modem connects to the internet wirelessly via super-fast mobile broadband. You can enjoy up to 100 Mbps downloads and 50 Mbps uploads, with no worries about USB dongle compatibility. And thanks to the wide coverage and 300 Mbps speed of 802.11n Wi-Fi, you can enjoy the 4G/LTE internet connection all around your home or office - perfect for those in locations where 4G/LTE speeds are faster than conventional ADSL or cable broadband. Convenient and cable-free, 4G-N12 will give you smoothly-streaming HD videos and fast file sharing anywhere. It can even connect to a cable modem to give a second internet connection for backup!
Faster 4G/LTE speed
With 4G-N12, you'll appreciate the blistering speed of the latest 4G/LTE mobile broadband technology, especially if you live out of reach of conventional broadband. It's capable of up to 100 Mbps downloads and 50 Mbps uploads - that's 3.5X faster than HSPA+ and twice as fast as DC HSPA+! -
Cable-free 3G/4G WAN and 300 Mbps Wi-Fi
Enjoy the cable-free convenience of 4G/LTE mobile broadband! 4G-N12 has a built-in SIM/USIM card slot that lets you share a mobile broadband connection via 300 Mbps Wi-Fi anywhere in the home or office. Surf the web, download apps, stream media and more - with no messy cables! -
4G/LTE and Ethernet dual-WAN support for interruption-free connections
In addition to its 4G/LTE capability, 4G-N12 has a dual-purpose Ethernet port that works either as a backup wired internet (WAN) connection, or as one of the four wired network (LAN) ports. This gives superb flexibility for business or home use - you need never be without an internet connection! -
Plug-n-Surf
It only takes three steps to get connected with 4G-N12.
- ASUS 4G-N12 - wireless router - WWAN - Wi-Fi - desktop
- Wireless router - wireless cellular modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Service Provider
- Service not included
- Mobile Communication Protocol
- UMTS, HSPA+, LTE, DC-HSPA+
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 300 Mbps
- NTP, ICMP/IP, PPPoE, DHCP
- Firewall protection, DMZ port, SPI, DoS attack prevention, dynamic DNS server, MAC address filtering, URL filtering, IP address filtering, event log, virtual server support, RADIUS support, WPS, static IP mode, UPnP Media Server, port triggering, dynamic IP mode, 802.1x authentication, ASUSWRT, keyword filtering
- IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, UPnP
- Power
- AC 120/230 V (50/60 Hz)
- Black
- 17.45 cm x 12.5 cm x 2.95 cm
- 300 g
- Wireless router - 4-port switch (integrated)
- Service Provider
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 300 Mbps
- Encryption Algorithm
- MPPE, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
- Authentication Method
- RADIUS
- Status Indicators
- Power, WAN, LAN, wireless, 3G, 4G
Communications
- Wireless cellular modem
- Max Transfer Rate
- 100 Mbps
- WAN / LAN: 1 x 10Base-T/100Base-TX - RJ-45 , LAN: 3 x 10Base-T/100Base-TX - RJ-45
- Expansion Slots
- 1 (total) / 1 (free) x SIM
- Power Device
- External power adapter
- Voltage Required
- Enclosure Colour
- Black
- Included Accessories
- 2 x SIM card adapter
- Cables Included
- 1 x network cable
- 17.45 cm
- 12.5 cm
- 2.95 cm
- 300 g
- 0 °C
- 40 °C
- 20 - 90% (non-condensing)
