VS239HV Full HD LED monitor, with 80,000,000:1 high contrast ratio and HDMI interface, is optimized for the finest image and color quality. This approach extends to the sturdy stand and slim profile without compromising style in ensuring stability and durability. ASUS exclusive QuickFit virtual scale instantly boosts design efficiency by providing real-size document, photo and grid on screen.
Superior image quality meets classic elegant design
VS239HV Full HD LED monitor, embedded the wide-viewing-angle IPS panel with 80,000,000:1 high contrast ratio and HDMI interface, is optimized for the finest image and color quality. This approach extends to the sturdy stand and slim profile without compromising style in ensuring stability and durability. -
80,000,000:1 ASUS smart contrast ratio
Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images. -
Full HD with HDMI
Enter a spectacular world of colors with Full HD 1080p (1920 x 1080) support and HDMI port. -
178° ultra wide viewing angle
VS239HV adopts ultra wide viewing angle IPS panel that eliminates color shift on your screen no matter where and how you look at it. -
Aspect control function
Aspect control function allows users to select a preferred display mode among full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion. -
The ASUS-exclusive QuickFit built in the monitor provides real-size document, photo, and grid mode on top of the operating Windows on the screen. It can activated via a hotkey on monitor and used as a guide to accurately view and edit photos. -
Splendid Video Intelligence technology
The exclusive Splendid Video Intelligence technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes can be selected via a hotkey.
- ASUS VS239HV - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.2652 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 80000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 55.2 cm x 20 cm x 40.03 cm
- 3.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, WEEE, GOST-R, J-MOSS, ErP Ready
- 3-year warranty
- Display Type
- Diagonal Size
- 23"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2652 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, input select, colour temperature, aspect control
- HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale
- Black
- 55.2 cm x 20 cm x 40.03 cm - with stand
- 3.5 kg
- VGA , DVI-D , HDMI , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable
- Input Voltage
- Power Consumption (Typical)
- 22 Watt
- Dimensions & Weight Details
- Without stand - width: 55.28 cm - depth: 4.5 cm - height: 33.4 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
