Asus VK228H 21.5" 1920x1080 2ms Integrated Webcam DVI VGA LED Monitor with Speakers
Quicklinx: 8BQBWS00 Mfr#: VK228H
This LCD monitor from ASUS provides a crisper, broader, and brighter display, plus a host of features that enhance your viewing experience. With these features, you can enjoy the convenience and delightful visual experience that the monitor brings to you!
ASUS VK228H - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class A
Energy Consumption per Year
29.2 kWh
Power Consumption (On mode)
20 W
Stereo speakers, camera
Panel Type
TN
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
2 ms
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
51.4 cm x 20 cm x 38.55 cm
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, PSB, RoHS, WEEE, GOST-R, J-MOSS, EuP
Display Type
Energy Class
Class A
29.2 kWh
Diagonal Size
21.5"
Built-in Devices
Panel Type
TN
Native Resolution
Pixel Pitch
0.248 mm
Pixel Per Inch
102
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
2 ms
Vertical Refresh Rate
76 Hz
Horizontal Refresh Rate
82 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
HDCP, anti-glare, Skin-Tone Selection, Trace Free Technology, ASUS Splendid Video Preset Mode, 72% NTSC colour gamut
51.4 cm x 20 cm x 38.55 cm - with stand
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , DVI-D , HDMI , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable, tilt adjustment
1 x VGA cable , 1 x DVI cable , 1 x audio cable , 1 x USB cable
Power Supply
Internal
Input Voltage
AC 120/230 V
20 W
Power Consumption (Typical)
25 Watt
Power Consumption Stand by / Sleep
0.5 Watt
0.5 Watt
Power Consumption Sleep
0.5 Watt
Included Software
Drivers & Utilities
Dimensions & Weight Details
Without stand - width: 51.41 cm - depth: 4.5 cm - height: 31.5 cm
Sustainability Information
ENERGY STAR Certified
