Great ethos underscores the choice of every single component that goes into your ASUS motherboard which ensuree long-term system reliability and performance. ASUS LANGuard socket has advanced signal-coupling technology and premium surface-mounted capacitors to improve throughput, while surge-protected and electrostatically-guarded components (ESD Guards) protect your motherboard from lightning strikes and static electricity. Onboard resettable fuses prevent overcurrent and short-circuit damage. This extends beyond I/O ports to DRAM to safeguard the lifespan of both your system and connected device.
Hardware safeguards to ensure long-term durability
Great ethos underscores the choice of every single component that goes into your ASUS motherboard which ensuree long-term system reliability and performance. -
LANGuard for advanced LAN protection
ASUS LANGuard socket has advanced signal-coupling technology and premium surface-mounted capacitors to improve throughput, while surge-protected and electrostatically-guarded components (ESD Guards) protect your motherboard from lightning strikes and static electricity. -
Enhanced DRAM overcurrent protection
Onboard resettable fuses prevent overcurrent and short-circuit damage. This extends beyond I/O ports to DRAM to safeguard the lifespan of both your system and connected device. -
5K-hr solid-state capacitors that last 2.5x longer
Solid-state capacitors are able to withstand extreme temperatures. This exceptional durability means superb real-world endurance to more typical PC operating temperatures, ensuring that ASUS motherboards continue working longer. -
Stainless-steel back I/O that lasts 3x longer
ASUS motherboard back I/O panels are made from strong and corrosion-resistant stainless steel, which is bonded with a thin layer of chromium oxide to enhance anti-corrosive properties. -
ESD Guards for protection from electrostatic discharge
Electrostatic discharge (ESD) can happen suddenly, and its damaging effects are easily underestimated. An active protective circuit design is employed to guard your system against electrostatic interference and damage, providing greater component longevity. -
Designed - great compatibility with ASUS products
When you choose an ASUS motherboard, it's likely you'll also go with ASUS for other components. ASUS designs products from the ground up so that graphics cards, sound cards and optical drives work flawlessly with your motherboard. -
Work with up to 3 displays
Connect up to three independent monitors at once using video outputs such as DisplayPort, Mini DisplayPort, HDMI, DVI, LVDS, or VGA. Choose your outputs and set displays to either mirror mode or collage mode. -
4K/Ultra HD visual excellence
Native support for 4K/UHD (ultra-high-definition) resolutions via HDMI or DisplayPort - that's four times the pixel count of 1080p, offering incredible visual clarity, detail, and realism. -
Media-acclaimed intuitive UFFI BIOS
Smooth, slick mouse-controlled graphical BIOS has been improved to make it even more appealing. Whether you're a PC novice or a seasoned overclocker, the EZ and Advanced modes help you find your way, quickly and easily. -
Active quiet and cool with Fan Xpert
ASUS Fan Xpert intelligently allows users to adjust both the CPU and chassis fan speed according to different ambient temperature, which is caused by different climate conditions in different geographic regions and system loading. Built-in variety of useful profiles offer flexible controls of fan speed to achieve a quiet and cool environment. -
Faster transfer speeds with USB 3.0 Boost
ASUS USB 3.0 Boost technology supports UASP USB 3.0. With USB 3.0 Boost technology, a USB device's transmission speed is significantly increased, adding to already fast USB 3.0 performance.
- ASUS N3150I-C - motherboard - mini ITX - Intel Celeron N3150
- Product Type
- Motherboard - mini ITX
- Processor
- Intel Celeron N3150 (Quad-Core)
- Max RAM Size
- 8 GB
- RAM Supported
- 2 DIMM slots - DDR3, non-ECC, unbuffered
- Storage Ports
- 2 x SATA-600
- USB / FireWire Ports
- 2 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 2 x USB 2.0 via headers)
- Graphics
- Intel HD Graphics
- Max Allocated RAM Size
- 512 MB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Processor
Supported RAM
- Max Size
- 8 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1066 MHz
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture
Graphics
- Graphics Controller
- Intel HD Graphics
- 512 MB
Audio
- Audio Codec
- Realtek ALC887-VD2
- High Definition Audio
LAN
- Network Controller
- Realtek RTL8111H
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 2 x DIMM 240-pin , 1 x PCIe 2.0 x4 (x1 mode)
- 2 x USB 2.0 , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 1 x PS/2 keyboard , 1 x VGA , 1 x PS/2 mouse , 1 x serial , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack
- Internal Interfaces
- 1 x LVDS - header , 2 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x parallel - header , 1 x serial - header , 1 x audio - header
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector
- BIOS Type
- AMI
- BIOS Features
- DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS MyLogo2, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, UEFI BIOS, ACPI 5.0 support, SMBIOS 2.8 support
- Sleep / Wake Up
- Wake on LAN (WOL), wake on PME
- Hardware Features
- ASUS Anti-Surge Protection, ESD Guards, ASUS EZ DIY, CrashFree BIOS 3, ASUS Fan Xpert, Fanless Design Heatsink, USB 3.0 Boost, Intel Smart Connect Technology, Low EMI Solution, ASUS 5X PROTECTION, ASUS Enhanced DRAM Overcurrent Protection, Preboot eXecution Environment (PXE), ASUS Stainless Steel Back I/O, LANGuard
- Included Accessories
- I/O back plate
- Cables Included
- 2 x Serial ATA cable
- Software Included
- ASUS MyLogo2, ASUS EZ Flash 2, ASUS AI Suite III, ASUS EZ Update, Antivirus (OEM version)
- Plug and Play
- 17 cm
- 17 cm
