ASUS Turbo GTX 960 is a special-edition graphics card with distinctive white coloring. Featuring an innovative modern dual-intake blower design and 10% larger heat-dissipation area, ASUS Turbo GTX 960 delivers 10% cooler performance and superior SLI configurations. It also comes equipped with a dual ball-bearing fan for a 4X longer card lifespan and exclusive Super Alloy Power components for superior stability.
The White Pinnacle of Cool Performance
ASUS Turbo GTX 960 is a special-edition graphics card with distinctive white coloring. Featuring an innovative modern dual-intake blower design and 10% larger heat-dissipation area, ASUS Turbo GTX 960 delivers 10% cooler performance and superior SLI configurations. It also comes equipped with a dual ball-bearing fan for a 4X longer card lifespan and exclusive Super Alloy Power components for superior stability. -
10% cooler than reference cards and 7% cooler when running SLI configurations
With 10% greater dissipation area and double-intake blower design, ASUS Turbo GTX 960 is 10% cooler than reference cards and 7% cooler when running SLI configurations. Tough ball-bearings on both sides of the fan housing provide greater strength and higher heat tolerance. With reduced friction, it also runs smoother, further improving 4X longer card lifespan. -
Dual-ball bearing fan
Without the problem of oil drying common in sleeve-bearing fans, the dual-ball bearing fan on ASUS Turbo GTX 960 lasts 4X longer. With reduced friction, it also runs smoother, further improving card lifespan and cooling efficiency. -
Enhanced durability and cooling
Exclusively formulated alloy components boost performance by reducing power loss, enhancing durability and facilitating cooler operation. Concrete-core chokes eliminate buzzing sounds under full load, and the card's capacitors have a 50,000-hour lifespan - 2.5X longer than traditional capacitors. -
Tweak till your heart's content
With an intuitive UI, GPU Tweak II makes overclocking easier than ever, and features Game Booster to maximize graphics performance and XSplit Gamecaster to stream or record your gameplay. -
XSplitGamecaster
Now, you can also launch XSplitGamecaster to bring up the in-game overlay and start streaming or recording your gameplay with the click of a button. You can also try the in-game annotations and video editor features to enhance your game stream experience.
- ASUS TURBO-GTX960-OC-4GD5 - graphics card - GF GTX 960 - 4 GB - white
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 960
- Memory
- 4 GB GDDR5
- Core Clock
- 1190 MHz
- Boost Clock
- 1253 MHz
- CUDA Cores
- 1024
- Effective Memory Clock
- 7.01 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 4096 x 2160
- DVI-I (dual link) , HDMI , 3 x DisplayPort
- API Supported
- OpenGL 4.4
- 3.7 cm x 26.4 cm x 12.1 cm
- Enclosure Colour
- White
- Microsoft Certification
- Compatible with Windows 7
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1190 MHz
- Boost Clock
- 1253 MHz
- CUDA Cores
- 1024
- Max Resolution
- 4096 x 2160
- API Supported
- OpenGL 4.4
- Dual Slot Fan Cooler, Native HDMI, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia Surround technology, Super Alloy Power technology, Nvidia SLI ready, NVIDIA Adaptive Vertical Sync, Dual ball Bearing Fan, NVIDIA GPU Boost 2.0, GPU Tweak Streaming, Dual-intake Blower Fan, HDCP
- Size
- 4 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 7.01 GHz
- Bus Width
- 128-bit
- Additional Requirements
- 6 pin PCI Express power connector
- 150 Watt
- Software Included
- Display drivers, XSplit Gamecaster (1 year Premium licence), ASUS GPU Tweak II
- 3.7 cm
- 26.4 cm
- 12.1 cm
- Enclosure Colour
- White
