Asus GeForce GTX 1060 TURBO 6GB GDDR5 PCIe3.0 Graphics Card
Quicklinx: C882WS00 Mfr#: TURBO-GTX1060-6G
ASUS Turbo GeForce® GTX 1060 delivers 4X-longer card lifespan
Dual-ball Bearing Fan runs smoother by reducing friction, further improving 4X longer card lifespan and cooling efficiency.
Industry Only Auto-Extreme Technology with Super Alloy Power II delivers premium quality and best reliability.
VR-friendly HDMI Ports for immersive virtual reality experiences.
Customisable Backlit Logo gives your system a truly unique look with your own LED backlit logo design.
GPU Tweak II with Xsplit Gamecaster provides intuitive performance tweaking and instant gameplay streaming.
NVIDIA ANSEL for a revolutionary new way to capture in-game screenshots.
NVIDIA GameWorks™ provides an interactive and cinematic experience, as well as incredibly smooth gameplay.
Perfect Your Build
ASUS Turbo GeForce® GTX 1060 comes equipped with a dual ball-bearing fan for a 4X longer card lifespan and exclusive Auto-Extreme Technology with Super Alloy Power II components for superior stability. Customisable backlit logo enables a system personalisation and VR-friendly HDMI ports let gamers easily enjoy immersive virtual reality experiences. ASUS Turbo GeForce® GTX 1060 also has GPU Tweak II with XSplit Gamecaster that provides intuitive performance tweaking and instant gameplay streaming.
Dual-Ball Bearing Fan
4X longer lifespan
Without the problem of oil drying common in sleeve-bearing fans, the dual-ball bearing fan on ASUS Turbo GeForce® GTX 1060 lasts 4X longer. With reduced friction, it also runs smoother, further improving card lifespan and cooling efficiency.
Premium quality and best reliability
ASUS graphics cards are produced using Auto-Extreme technology, an industry-first 100% automated production process, and feature premium Super Alloy Power II components that enhance efficiency, reduce power loss, decrease component buzzing under load, and lower thermal temperatures for unsurpassed quality and reliability.
VR-Friendly HDMI Ports
Enjoy immersive virtual reality experience
ASUS Turbo GeForce® GTX 1060 graphics cards have two HDMI ports for connecting a VR device and display at the same time, so you can enjoy immersive virtual reality experiences anytime without having to swap cables.
An unique look for your system
ASUS Turbo GeForce® GTX 1060 comes with an LED backlit ASUS logo that you can swap with your own custom design for a truly unique look.
  • Powered by NVIDIA® GeForce® GTX 1060
  • GeForce® GTX VR Ready
  • NVIDIA® G-SYNC ready
  • PCIE 3.0
  • Dual-ball bearing fan for longer lifespan
    Without the problem of oil drying common in sleeve-bearing fans, the dual-ball bearing fan on ASUS TURBO lasts longer. With reduced friction, it also runs smoother, further improving card lifespan and cooling efficiency.
  • Auto-Extreme technology with Super Alloy Power II for premium quality and reliability
    ASUS graphics cards are produced, using Auto-Extreme technology, an automated production process, and feature premium Super Alloy Power II components, that enhance efficiency, reduce power loss, decrease component buzzing under load, and lower thermal temperatures for unsurpassed quality and reliability.
  • VR-friendly HDMI ports
    ASUS TURBO graphics cards have two HDMI ports for connecting a VR device and display at the same time, so you can enjoy immersive virtual reality experiences anytime, without having to swap cables.
ASUS TURBO-GTX1060-6G - graphics card - GF GTX 1060 - 6 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1060
6 GB GDDR5
Core Clock
1506 MHz
Boost Clock
1708 MHz
CUDA Cores
1280
Effective Memory Clock
8.008 GHz
Memory Interface
192-bit
Max Resolution
7680 x 4320
Interfaces Details
DVI-D (dual link) , 2 x HDMI , 2 x DisplayPort
API Supported
OpenGL 4.5
3.81 cm x 26.67 cm x 11.12 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1506 MHz
Boost Clock
1708 MHz
CUDA Cores
1280
VR Ready
Max Resolution
7680 x 4320
Interfaces Details
API Supported
OpenGL 4.5
Dual Slot Fan Cooler, Native HDMI, Dual ball Bearing Fan, NVIDIA G-Sync ready, NVIDIA GameWorks, Super Alloy Power II technology, Nvidia GeForce GTX VR Ready, NVIDIA Ansel, HDCP
Size
6 GB
GDDR5 SDRAM
Effective Clock Speed
8.008 GHz
Bus Width
192-bit
Additional Requirements
6 pin PCI Express power connector
Software Included
Display drivers, ASUS GPU Tweak II, XSplit Gamecaster 2 (1 year Premium licence)
3.81 cm
26.67 cm
11.12 cm
C882 C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £13.17
