Asus GeForce GTX 1050 Ti 4GB GDDR5 PCIe 3.0 Graphics Card
Quicklinx: CGF0WS00 Mfr#: EX-GTX1050TI-4G
  • High-Definition Multimedia Interface (HDMI)
  • DisplayPort
GEFORCE GTX 1050
ESSENTIAL GEAR FOR EVERY GAMER
Everyone deserves great gaming. That’s why we created the fast, powerful GeForce® GTX 1050. Now, you can turn your PC into a true gaming rig, powered by NVIDIA Pascal™—the most advanced GPU architecture ever created. It’s loaded with innovative NVIDIA Game Ready technologies that let every gamer experience the latest titles in their full glory. #GameReady.
ASUS Expedition GeForce® GTX 1050 Ti eSports gaming graphics card 4GB GDDR5:
Exclusive World of Warships invite code for free: Diana Cruiser and 15-day Premium Account (worth USD11). - game codes redemption starts from 7/31/2015 to 1/30/2017. Please stay tuned on http://www.asus.com/event for details.
Dual-ball Bearing 0dB Fan runs smoother by reducing friction, further improving 2X longer card lifespan and cooling efficiency. Play in silence with 0dB fans.
Easy plug and play gaming with no extra power supply needed.
Industry only Auto-Extreme Technology with Super Alloy Power II delivers premium quality and the best reliability.
GPU Tweak II with XSplit Gamecaster provides intuitive performance tweaking and instant gameplay streaming.
NVIDIA ANSEL for a revolutionary new way to capture in-game screenshots.
NVIDIA GameWorks™ provides an interactive and cinematic experience, as well as incredibly smooth gameplay.
Build for Non-Stop Action
ASUS Expedition graphics cards are made for non-stop action, engineered with non-stop durability for 2X longer lifespan and premium reliability. We even test the cards to the limits, with 144 hour of diskless-system tests and extensive checks for compatibility with top games. While GPU Tweak II with XSplit Gamecaster to provide non-stop gaming experience and real-time streaming.
I/O Ports Highlight
1 x Native DVI-D
1 x Native HDMI 2.0
1 x Native Display Port
NON-STOP DURABILITY
2X Longer Lifespan
Without the problem of oil drying common in sleeve-bearing fans, the dual-ball bearing fan on ASUS Expedition GeForce® GTX 1050 Ti lasts 2X longer. With reduced friction, it also runs smoother, further improving card lifespan and cooling efficiency. You can play in true 0dB silence as the 0dB fans remain off up to a set GPU temp level.
NON-STOP GAMING
GPU Tweak II: Intuitive Performance Tweaking
Redesigned with an intuitive, all-new UI, GPU Tweak II makes overclocking easier and more visual than ever, while still retaining advanced options for seasoned overclockers. With one click, the new Gaming Booster function maximizes graphics performance by removing redundant processes and allocating all available resources automatically. XSplit Gamecaster lets you easily stream or record your gameplay right from a convenient, in-game overlay.
Game Ready
Extraordinary performance. Game-changing experiences. Perfectly tuned. Game Ready with GeForce GTX 10-Series graphics cards.
  • Build for non-stop action
  • 2X longer lifespan
    Without the problem of oil drying common in sleeve-bearing fans, the dual-ball bearing fan on ASUS Expedition GeForce GTX 1050 Ti lasts 2X longer. With reduced friction, it also runs smoother, further improving card lifespan and cooling efficiency. You can play in true 0dB silence as the 0dB fans remain off up to a set GPU temp level.
  • Premium quality and reliability
    ASUS graphics cards are produced using Auto-Extreme technology, an industry-first 100% automated production process, and features premium Super Alloy Power II components that enhance efficiency, reduce power loss, decrease component buzzing under load, and lower thermal temperatures for unsurpassed quality and reliability.
  • GPU Tweak II: intuitive performance tweaking
    Redesigned with an intuitive, UI, GPU Tweak II makes overclocking easier and more visual than ever, while still retaining advanced options for seasoned overclockers. With one click, the Gaming Booster function maximizes graphics performance by removing redundant processes and allocating all available resources automatically. XSplit Gamecaster lets you easily stream or record your gameplay right from a convenient, in-game overlay.
ASUS EX-GTX1050TI-4G - graphics card - GF GTX 1050 Ti - 4 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1050 Ti
4 GB GDDR5
Core Clock
1290 MHz
Boost Clock
1392 MHz
CUDA Cores
768
Effective Memory Clock
7.008 GHz
Memory Interface
128-bit
Max Resolution
7680 x 4320
Interfaces Details
DVI-D (dual link) , HDMI , DisplayPort
API Supported
OpenGL 4.5
3.8 cm x 21.2 cm x 11.1 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1290 MHz
Boost Clock
1392 MHz
CUDA Cores
768
Max Resolution
7680 x 4320
Interfaces Details
API Supported
OpenGL 4.5
Native HDMI, NVIDIA Adaptive Vertical Sync, Dual ball Bearing Fan, NVIDIA GPU Boost 2.0, NVIDIA GameWorks, Super Alloy Power II technology, AUTO-EXTREME technology, NVIDIA Ansel, NVIDIA Pascal GPU technology, HDCP
Size
4 GB
GDDR5 SDRAM
Effective Clock Speed
7.008 GHz
Bus Width
128-bit
Software Included
Display drivers, ASUS GPU Tweak II, World of Warships invite code, XSplit Gamecaster 2 (14 days Premium licence)
3.8 cm
21.2 cm
11.1 cm
