GT 730 is the astonishing high-value graphics card from ASUS! Equipped with the GeForce GT 730 graphics-processing unit (GPU), ASUS GT730-2GD3 includes some brilliant technologies that you can get only from ASUS. ASUS is fitted dust-proof fan for 25%-longer lifespan, and equipped the card with the exclusive Super Alloy Power components for superior stability. GT730-2GD3 also comes with the easy-to-use tuning tool, GPU tweak. Use this to squeeze every last drop of performance out of the card and then stream your pumped-up on-screen action over the Internet in real time!
Raging cool for the win
GT 730 is the astonishing high-value graphics card from ASUS! Equipped with the GeForce GT 730 graphics-processing unit (GPU), ASUS GT730-2GD3 includes some brilliant technologies that you can get only from ASUS. ASUS is fitted dust-proof fan for 25%-longer lifespan, and equipped the card with the exclusive Super Alloy Power components for superior stability. GT730-2GD3 also comes with the easy-to-use tuning tool, GPU tweak. Use this to squeeze every last drop of performance out of the card and then stream your pumped-up on-screen action over the internet in real time! -
Dust-proof fan - 25% longer graphics card lifespan
Unique fan design dissipates heat efficiently while extending a graphic card's lifespan by 25% through increased dust and particle resistance. -
Super alloy power - enhanced durability and cooling
Exclusively-formulated alloy components boost performance by reducing power loss, enhancing durability, and achieving cooler operation. Choke concrete cores eliminate buzzing sound under full load while capacitors assure a 50,000-hour lifespan: equivalent to 2.5 times longer than traditional capacitors. -
Stream online instantly
GPU tweak streaming tool that lets you share on-screen action in real time - so others can watch live as games is played. It's even possible to add to the streaming window scrolling text, pictures and webcam images.
- ASUS GT730-2GD3 - graphics card - GF GT 730 - 2 GB
- Graphics card
- Bus Type
- PCI Express 2.0
- Graphics Engine
- NVIDIA GeForce GT 730
- Memory
- 2 GB DDR3
- Core Clock
- 700 MHz
- CUDA Cores
- 96
- Effective Memory Clock
- 1.6 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 2560 x 1600
- DVI-I (dual link) , VGA , HDMI
- API Supported
- DirectX 11, OpenGL 4.3
- 3.5 cm x 16.3 cm x 11.1 cm
- Microsoft Certification
- Compatible with Windows 7
- Graphics card
- Bus Type
- PCI Express 2.0
- Graphics Engine
- Core Clock
- 700 MHz
- CUDA Cores
- 96
- Max Resolution
- 2560 x 1600
- API Supported
- Native HDMI, Nvidia PhysX-Ready, Super Alloy Power technology, Dust-proof fan, NVIDIA Adaptive Vertical Sync, GPU Tweak Streaming, HDCP
- Size
- 2 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1.6 GHz
- Bus Width
- 128-bit
- Software Included
- Drivers & Utilities, ASUS GPU Tweak
- 3.5 cm
- 16.3 cm
- 11.1 cm
