PLEASE NOTE: These Graphics Cards Do NOT Ship With Low Profile Brackets From April 1st 2013
GT620-1GD3-L-V2: Ultra-smooth Full HD 3D Enjoyment
- Resists dust and particles for 25% longer graphics card longevity
- Premium alloys in power delivery components defeat heat for cards that run 15% faster and last 2.5 times longer than reference.
- GPU Tweak helps you modify clock speeds, voltages, fan performance and more, all via an intuitive interface.
Every PC deserves great graphics. The NVIDIA GeForce GT 620 graphics card gives you a superior multimedia experience, every time. Count on NVIDIA dedicated graphics for a faster, more immersive experience in your favorite applications.
Long graphics card lifespan
Unique fan design dissipates heat efficiently while extending a graphic card's lifespan by 25% through increased dust and particle resistance. -
Enhanced durability and cooling
Exclusively-formulated alloy components boost performance by reducing power loss, enhancing durability, and achieving cooler operation. Choke concrete cores eliminate buzzing sound under full load while capacitors assure a 50000-hour lifespan: equivalent to 2.5 times longer than traditional capacitors. -
Gigantic DDR3 memory
On-board memory is design for the best gaming experience and the best resolution. -
GeForce CUDA supported
Unlocks the power of GPU's processor cores to accelerate the most demanding system tasks. -
NVIDIA PhysX ready
Dynamic visual effects like blazing explosions, reactive debris, realistic water, and lifelike characters. -
Microsoft DirectX 11 supported
Bring new levels of visual realism to gaming on the PC and get top-notch performance. -
Supports large and high resolution
Dual-link DVI is able to drive the industry's largest and highest resolution flat-panel displays up to 2560 x 1600.
- ASUS GT620-1GD3-L-V2 - graphics card - GF GT 620 - 1 GB
- Graphics card
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- NVIDIA GeForce GT 620
- Memory
- 1 GB DDR3
- Core Clock
- 700 MHz
- Effective Memory Clock
- 1.2 GHz
- Memory Interface
- 64-bit
- Max Resolution
- 2560 x 1600
- Max Resolution Details
- DVI: 2560 x 1600 / VGA: 2048 x 1536
- DVI-I (dual link) , VGA , HDMI
- API Supported
- DirectX 11
- 2.29 cm x 16.9 cm x 12.2 cm
- Microsoft Certification
- Compatible with Windows 7
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 700 MHz
- Max Resolution
- 2560 x 1600
- API Supported
- DirectX 11
- Nvidia CUDA technology, Nvidia PhysX-Ready, Super Alloy Power technology, Dust-proof fan, HDCP
- Size
- 1 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1.2 GHz
- Bus Width
- 64-bit
- 75 Watt
- Software Included
- Drivers & Utilities, ASUS GPU Tweak
- 2.29 cm
- 16.9 cm
- 12.2 cm
