Asus GeForce GT 610 1GB PCI-Express HDMI Silent Low Profile
Quicklinx: 83T3WS00 Mfr#: GT610-SL-1GD3-L
  • High-Definition Multimedia Interface (HDMI)
PLEASE NOTE: These Graphics Cards Do NOT Ship With Low Profile Brackets From April 1st 2013
ASUS GT610-SL-1GD3-L: GT610 0dB, fanless graphics card with DirectX®11, HDMI support
  • Exclusive 0dB thermal design dissipates heat efficiently without any noise
  • HTPC ready design with low profile bracket bundled
  • Full HD multimedia entertainment with DX11 and HDMI support
Efficiently Silent, Visually Vibrant
Super Alloy Power
The exclusive alloyed components helps boost performance by reducing power loss, enhancing durability and achieving cooler operation. The chokes' concrete core eliminates the buzz sound in full load while the capacitors assure a 50,000 hours lifespan - equivalent to 2.5 times longer than traditional capacitors.
GPU Tweak
  • Real-time and intuitive graphics tuning
  • Detailed specs and actual card status with GPU-Z
  • Monitoring widget provides real-time and detailed multi-parameter info
  • 2D/ 3D switcher can lock the card in 3D mode for higher benchmarks
  • Automatically check and update drivers and BIOS versions
  • Sync GPU clocks and voltages for easier overclocking
OdB Silent Cooling
Silent passive cooling runs 0dB quiet, perfect for hushed gaming and multimedia joy.
Low Profile Design
Ideal for home theater PCs and multimedia centers with low profile design and high power efficiency.
  • 0 db cooling
    Exclusive 0 db thermal design dissipates heat efficiently without any noise.
  • GPU tweak
    GPU tweak co-developed with the most authoritative GPUZ to provide the most accurate information.
  • DDR3 memory
    On-board memory for the best gaming experience and the best resolution.
  • 40 nm GPU
    The 40 nm GPU less power consumption and more efficient transistor.
  • Microsoft DirectX 11 support
    It brings new levels of visual realism to gaming on the PC and gets top-notch performance.
  • NVIDIA PhysX ready
    Dynamic visual effects like blazing explosions, reactive debris, realistic water, and lifelike characters.
  • GeForce CUDA support
    CUDA technology unlocks the power of GPU's processor cores to accelerate the most demanding system tasks.
  • Take your game beyond HD
    Dual-link DVI is able to drive the industry's large and high resolution flat-panel display up to 2560 x 1600.
ASUS GT610-SL-1GD3-L - graphics card - GF GT 610M - 1 GB
Graphics card - low profile
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA GeForce GT 610M
1 GB DDR3
Core Clock
810 MHz
Effective Memory Clock
1.2 GHz
RAMDAC
400 MHz
Memory Interface
64-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 / VGA: 2048 x 1536
VGA , DVI-I (dual link) , HDMI
API Supported
DirectX 11
Fanless
Microsoft Certification
Compatible with Windows 7
Graphics card - low profile - fanless
Bus Type
PCI Express 2.0 x16
Graphics Engine
Core Clock
810 MHz
RAMDAC
400 MHz
Process Technology
40 nm
Max Resolution
2560 x 1600
API Supported
DirectX 11
ASUS 0-dB thermal solution, Nvidia PhysX-Ready, Super Alloy Power technology, HDCP
Size
1 GB
DDR3 SDRAM
Effective Clock Speed
1.2 GHz
Bus Width
64-bit
Software Included
Drivers & Utilities, ASUS GPU Tweak
