The ASUS DSL-N14U ADSL modem router has Wi-Fi speeds up to 300 Mbps. It replaces the ADSL modem from your internet service provider, saving space and reducing clutter. With easy, CD-free installation and reliable data transmission, DSL-N14U is a complete wireless solution for ADSL users, and also features a multifunctional USB 2.0 port.
With the easy-to-use ASUSWRT dashboard you can setup, monitor and control your network from one intuitive interface. DSL-N14U features special ADSL-related enhancements to the intuitive ASUSWRT graphical interface, including a signal-to-noise ratio (SNR) measuring tool that can help customers monitor the stability of an ADSL connection. With DSL-N14U you can easily set up a VPN server for secure web browsing and data access - no matter where you are. Featuring PPTP encryption, your connection will always be secure and confidential.
Fast Wi-Fi, with more space and less clutter
The ASUS DSL-N14U ADSL modem router has Wi-Fi speeds up to 300 Mbps. It replaces the ADSL modem from your Internet service provider, saving space and reducing clutter. With easy, CD-free installation and reliable data transmission, DSL-N14U is a complete wireless solution for ADSL users, and also features a multifunctional USB 2.0 port. -
Easy 30-second router setup
Use your smartphone, tablet, or PC to effortlessly set up your ASUS router in less than 30 seconds and in only 3 easy steps. Simply connect the cables to the router, open a Web browser, and follow the setup wizard to get you to the Internet in no time. -
Multi-functional built-in USB port
The built-in USB 2.0 port allows you to connect external storage, printers, and other devices to the DSL-N14U and share them with other users over the network. -
Robust control and optimization with ASUSWRT
With the easy-to-use ASUSWRT dashboard you can setup, monitor and control your network from one intuitive interface. DSL-N14U features special ADSL-related enhancements to the intuitive ASUSWRT graphical interface, including a signal-to-noise ratio (SNR) measuring tool that can help customers monitor the stability of an ADSL connection. -
VPN server enabled
With DSL-N14U you can easily set up a VPN server for secure web browsing and data access - no matter where you are. Featuring PPTP encryption, your connection will always be secure and confidential. -
Discrete and secure Wi-Fi networks via guest access
DSL-N14U supports up to four wireless networks over the 2.4 GHz band, so you can set up usage times and limit access with advanced controls, including parental settings.
- ASUS DSL-N14U - wireless router - DSL modem - Wi-Fi - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL, ADSL2, ADSL2+
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 300 Mbps
- PPTP, L2TP, IPSec
- NAT support, Stateful Packet Inspection (SPI), DoS attack prevention, print server, MAC address filtering, IPv6 support, VPN passthrough, URL filtering, parental control, firmware upgradable, Virtual Protocol Interconnect (VPI), download client, file sharing, event log, RADIUS support, Wi-Fi Protected Setup (WPS), IPSec passthrough, FTP server, Multiple SSID support, ASUS AiDisk, reset button, IPv4 support, port configuration, VPN Server, ASUS AiCloud, ASUSWRT
- IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, ANSI T1.413i2
- Power
- AC 120/230 V (50/60 Hz)
- Diamond black
- 12.3 cm x 19 cm x 3.5 cm
- 314 g
- System Requirements
- Linux, Apple MacOS X, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
- Localisation
- European Union
- 3-year warranty
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 300 Mbps
- Selectable Channels Qty
- 13
- PPTP, L2TP, IPSec
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
- Authentication Method
- RADIUS
- IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, ANSI T1.413i2, ETSI
- Processor
- Ralink
- RAM
- 64 MB DDR2 SDRAM
- Flash Memory
- 16 MB
- Status Indicators
- Power, WLAN, WAN, LAN, USB, ADSL
Line Properties
- Framing Format
- ANSI T1.413i2
Communications
- DSL modem
- Protocols & Specifications
- ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.992.3 (G.DMT.bis), ITU G.992.4 (G.lite.bis), ITU G.992.5, ITU G.992.3 Annex A, ITU G.992.3 Annex L, ITU G.992.3 Annex M, ITU G.992.3 Annex B
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , WAN: 1 x ADSL2+ - RJ-11
Aerial
- Aerial
- External detachable
- Antenna Qty
- 2
- Gain Level
- 2 dBi
- Power Device
- External power adapter
- Voltage Required
- Enclosure Colour
- Diamond black
- Cables Included
- 1 x network cable , 1 x modem cable
- Localisation
- European Union
- Software Included
- Drivers & Utilities
- OS Required
- 12.3 cm
- 19 cm
- 3.5 cm
- 314 g
- Limited warranty - 3 years
- -10 °C
- 50 °C
- 5 - 95% (non-condensing)
