The motherboards are proven to be compatible with more than 1,000 components and devices, and undergo a strict validation. That gives you the peace of mind of knowing that ASUS motherboards are fit for all environments and applications. To build your PC with the best foundations, build it with an ASUS motherboard.
The be-the-best ethos underscores the choice of every single component that goes into your ASUS motherboard. People focus relentlessly on quality to ensure long-term system reliability and performance.
The motherboards have superb endurance. A barrage of burn-in, environmental, compatibility, software and safety tests confirm that the motherboards are exceptionally robust - with reliability that surpasses industry standards.
Proven quality, enduring trust - strict compatibility and validation
The motherboards are proven to be compatible with more than 1,000 components and devices, and undergo a strict validation. That gives you the peace of mind of knowing that ASUS motherboards are fit for all environments and applications. To build your PC with the best foundations, build it with an ASUS motherboard. -
ASUS 5x protection - hardware safeguards to ensure long-term durability
The be-the-best ethos underscores the choice of every single component that goes into your ASUS motherboard. People focus relentlessly on quality to ensure long-term system reliability and performance. -
Top-to-bottom reliability
The motherboards have superb endurance. A barrage of burn-in, environmental, compatibility, software and safety tests confirm that the motherboards are exceptionally robust - with reliability that surpasses industry standards. -
Media-acclaimed UEFI BIOS
The smoothest, slickest mouse-controlled graphical BIOS has been improved to make it even more appealing. Whether you're a PC novice or a seasoned overclocker, the EZ and Advanced Modes help you find your way, quickly and easily. -
Ultimate cooling and quietness with Fan Xpert 2
ASUS Fan Xpert intelligently allows you to adjust CPU and case fan speeds according to different ambient temperatures in diverse climate conditions and locations, as well as actual PC loading. Various preset fan performance profiles offer flexible fan speed controls to achieve a quiet and cool environment. -
Ultra-fast, always
With the latest USB 3.1 connectivity built in and Type A & Type C ports for the very fastest USB data transfers, you'll experience data-transfer speeds of up to 10 Gbit/s - or twice as fast USB 3.0. The next-generation standard is completely backward-compatible with your existing USB devices, and you'll be all set for USB 3.1's breakneck speeds. And ASUS-exclusive USB 3.1 Boost technology automatically accelerates USB 3.1 performance even further!
- ASUS B85M-G PLUS/USB 3.1 - motherboard - micro ATX - LGA1150 Socket - B85
- Product Type
- Motherboard - micro ATX
- Chipset Type
- Intel B85 Express
- Processor Socket
- 1 x LGA1150 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7
- Max RAM Size
- 32 GB
- RAM Supported
- 4 DIMM slots - DDR3, non-ECC, unbuffered
- Storage Ports
- 4 x SATA-600, 2 x SATA-300
- USB / FireWire Ports
- 1 x USB-C + 1 x USB 3.1 + 2 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
- Max Allocated RAM Size
- 1024 MB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Chipset Type
- Intel B85 Express
- Processor Socket
- LGA1150 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz, 1066 MHz
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
- 1024 MB
Audio
- Audio Codec
- Realtek ALC887-VD2
- High Definition Audio
LAN
- Network Controller
- Realtek RTL8111GR
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 240-pin , 1 x PCIe 3.0 x16 , 2 x PCIe 2.0 x1
- Storage Interfaces
- SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices , SATA-300 -connectors: 2 x 7pin Serial ATA - 2 devices
- 1 x PS/2 keyboard , 1 x PS/2 mouse , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DVI-D , 1 x HDMI , 4 x USB 2.0 , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out - mini-jack , 1 x USB 3.1 , 1 x USB-C
- Internal Interfaces
- 4 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x SPDIF out - header , 1 x audio - header , 1 x serial - header
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector
- BIOS Type
- AMI
- BIOS Features
- DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS MyLogo2, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, UEFI BIOS, SMBIOS 2.7 support
- Sleep / Wake Up
- Wake on LAN (WOL), wake on ring (WOR), wake on PME
- Hardware Features
- Jack retasking, ASUS Anti-Surge Protection, ASUS Q-Design, ESD Guards, Q-DIMM, GPU Boost, ASUS EZ DIY, Q-Slot, CrashFree BIOS 3, All-Solid Capacitor motherboard Design, audio jack detect technology, ASUS EPU (Energy Processing Unit), Intel Extreme Memory Profile (XMP) support, Intel Turbo Boost Technology 2.0, ASUS DIGI+ VRM, Intel Clear Video HD Technology, Conductive Polymer Capacitors, ASUS Fan Xpert 2, Intel Rapid Start Technology, Intel Smart Connect Technology, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, ASUS 5X PROTECTION, ASUS Enhanced DRAM Overcurrent Protection, ASUS Boot Setting, Preboot eXecution Environment (PXE), Clear CMOS Button, ASUS Stainless Steel Back I/O, USB 3.1 Boost
- Included Accessories
- I/O back plate
- Cables Included
- 2 x Serial ATA cable
- Software Included
- Drivers & Utilities, ASUS MyLogo2, ASUS EZ Flash 2, ASUS AI Charger, ASUS Update, ASUS AI Suite III, Antivirus (OEM version)
- Plug and Play, ACPI 2.0a
- 23.3 cm
- 21.1 cm
