Compact gaming punch with awesome RGB lighting
LGA1151 socket for 6th-genereation Intel® Core™ i7 / Core i5 / Core i3, Pentium® and Celeron processors
Dual-channel DDR4 2133 support
SupremeFX: Flawless audio that makes you part of the game
Sonic Radar ll: Scan and detect your enemies to dominate
Intel Gigabit Ethernet and LANGuard: Top-speed protected networking
RAMCache: Speed up your game loads
Gamer's Guardian: Highly-durable components and smart DIY features
M.2: Ultra-speedy transfers for faster gaming
BRIGHTEN YOUR BUILD WITH CUSTOMISABLE RGB LED ILLUMINATION
Gaming is about your style, your personality — and your passion. B150I Pro Gaming/Aura is the gaming motherboard that lets you inject passion to project your style and personality in full colour! Aura, our all-new LED-illumination technology, lighting up an endless spectrum of colour combinations coupled with a selection of fascinating and fun effects.
Sonic Radar II
Scan and detect to dominate!
Sonic Radar II displays a stealthy overlay that shows what your opponents and teammates are up to on the battlefield, all managed via a simple control panel and customizable game list. See the direction and origin of key in-game sounds, and practice your enemy-pinpointing skill, plus Audio Enhancement technology clarifies every last sound — so you hear the distant sound of enemy footsteps and become the hunter, not the hunted!
TOP-SPEED PROTECTED NETWORKING
Only the quickest shot survive, so B150I Pro Gaming/Aura banishes lag — letting you annihilate your foes as fast as your trigger finger! Our engineers pack in only the best networking technology, including tournament-level Intel® Gigabit Ethernet and ASUS-exclusive LANGuard and GameFirst technologies to keep your connection fast, so always fire first and watch your enemies fall.
Award-winning BIOS design
The smoothest, slickest mouse-controlled graphical BIOS has been improved to make it even more appealing. Whether you're a PC novice or a seasoned overclocker, the EZ and Advanced Modes help you find your way. In EZ Mode you can get set up very quickly, applying the date and time, fan profiles and Intel Extreme Memory Profile (XMP) memory profiles. Switch to Advanced Mode to set up favorites and shortcuts, record and review recent changes with Last Modified or make notes in Quick Notes.
Brighten your build with customizable RGB LED illumination
Gaming is about your style, your personality - and your passion. B150I Pro Gaming/Aura is the gaming motherboard that lets you inject passion to project your style and personality in full color! Aura, LED-illumination technology, lighting up an endless spectrum of color combinations coupled with a selection of fascinating and fun effects. -
Be the best on the battlefield with B150I Pro Gaming/Aura's truly immersive SupremeFX audio and experience sound so alive with realism that it hands you the vital competitive edge needed to win. With near-lossless delivery and exclusive Sonic Radar II technology to pinpoint battlefield enemies before they spot you, SupremeFX sounds stupendous - and puts both your ears and frags in front of everyone else! -
Shielded audio, superior sound
SupremeFX technology delivers high-fidelity, near-lossless audio no matter how frantic your game becomes. The purity and stability of the remarkable 112 dB signal-to-noise ratio (SNR) is assured, with a shielded design, electromagnetic-interference (EMI) cover and voltage-protected power supply. -
Illuminated shielding
Banish analog interference and enjoy eye-catching, customizable lighting effects. -
EMI cover
Effective shielding against electromagnetic interference preserves the integrity of audio signals for the ultimate quality. -
Premium Nichicon audio capacitors
Fine-quality components that produce a warmer, natural sound with exceptional clarity and fidelity. -
Sonic Radar II displays a stealthy overlay that shows what your opponents and teammates are up to on the battlefield, all managed via a simple control panel and customizable game list. See the direction and origin of key in-game sounds, and practice your enemy-pinpointing skill, plus Audio Enhancement technology clarifies every last sound - so you hear the distant sound of enemy footsteps and become the hunter, not the hunted! -
B150I Pro Gaming/Aura banishes lag - letting you annihilate your foes as fast as your trigger finger! Intel Gigabit Ethernet and LANGuard with GameFirst technologies keep your connection fast, so fire first and watch your enemies fall. -
More throughput, less CPU usage and great gaming experiences
Featuring Intel Ethernet for faster, smoother gaming. Intel's LAN has the serious double advantage of reducing CPU overhead and offering exceptionally high TCP and UDP throughput. This significantly reduces the processor's workload, so there's more power for your game and your gameplay. -
Pumped-up throughput, ultimate surge protection
LANGuard means safer, more reliable connections for your battles! Advanced signal-coupling technology and premium surface-mounting processes join forces to protect your B150I Pro Gaming/Aura's connection and deliver pumped-up throughput, plus electrostatically-guarded and surge-protected components (ESD Guards) for greater tolerance to static electricity and greater protection against surges! -
Multi-gate teaming
Team all your network gateways for maximum bandwidth and assign connections to every application for the smooth gameplay. -
FAN Xpert2+
Play quieter and cooler with advanced fan and water-pump controls for the ultimate cooling in undisturbed gaming. Fan Xpert 2+ puts 4-pin/3-pin CPU and case fan controls in one place. It scans each fan's characteristics and delivers custom settings for each fan based on the dedicated area temperatures detected by hardware thermal sensors. -
GPU Boost
ASUS GPU Boost technology lets you accelerate B150I Pro Gaming/Aura integrated GPU for extreme graphics performance safely and easily via a user-friendly interface! -
USB 3.0 Boost
This great technology accelerates the already-fast speed of USB 3.0, enabling transfer speeds that are much faster than standard USB 3.0. -
Speed your game loads
Uniquely-intelligent technology that effectively caches an entire storage device so that favorite games and apps launch at breakneck speeds, getting to work the moment it's activated. RAMCache turns milliseconds into microseconds to boost game-load times to stratospheric levels! -
Speed up with onboard PCIe NVMe M.2
With x4 PCI Express 3.0/2.0 bandwidth, M.2 supports high data-transfer speeds. It is the perfect solution for an operating system or application drive, making your whole PC or professional apps work as fast as possible. -
Gamer's guardian for real-world protection
Protect your back in the game and let B150I Pro Gaming/Aura protect all sides in the real world! Motherboard self-protection with loads of brilliant defenses, including unique smart DIY features ensures long-term gaming is in your future. -
DRAM overcurrent protection
All connection ports and DRAM are protected against overcurrent and short-circuit damage by onboard resettable fuses, extending your motherboard's life. -
Stainless steel back I/O
Crafted from chromium-plated, corrosion-resistant stainless steel, the input/output (I/O) panel is much longer than ordinary panels! -
Greater ESD protection for extended component lifespan
Electrostatic discharge (ESD) could mean game over for your rig, so B150 Pro Gaming/Aura is protected by ESD Guards to actively prevent ESD - ensuring longer component lifespan and providing system resilience that's two times greater than industry standards. Game on! -
Audio connector
Capacitor protection on both front and back audio-output circuits. -
LAN connector
ESD TVS diode protection and an anti-surge LAN connector protects against extreme events, such as lightning strikes.
- ASUS B150I PRO GAMING/AURA - motherboard - mini ITX - LGA1151 Socket - B150
- Product Type
- Motherboard - mini ITX
- Chipset Type
- Intel B150
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
- Max RAM Size
- 32 GB
- RAM Supported
- 4 DIMM slots - DDR4, non-ECC, unbuffered
- Storage Ports
- 4 x SATA-600, 1 x M.2
- USB / FireWire Ports
- 1 x USB-C + 2 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 2 x USB 2.0 via headers)
- Max Allocated RAM Size
- 1024 MB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Chipset Type
- Intel B150
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
- 1024 MB
Audio
- Audio Codec
- SupremeFX
- High Definition Audio
LAN
- Network Controller
- Intel I219V
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16
- Storage Interfaces
- SATA-600 / PCIe 3.0 -connectors: 4 x 7pin SATA, 1 x M.2
- 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 1 x USB-C , 1 x PS/2 keyboard / mouse , 1 x DVI , 1 x HDMI , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x TOSLINK
- Internal Interfaces
- 2 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support
- Sleep / Wake Up
- Wake on LAN (WOL), wake on PME
- Hardware Features
- Jack retasking, ASUS Q-Design, GameFirst, ESD Guards, Q-DIMM, Q-LED, CrashFree BIOS 3, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, Intel Extreme Memory Profile (XMP) support, Intel Turbo Boost Technology 2.0, ASUS DIGI+ VRM, Intel Clear Video HD Technology, Fanless Design Heatsink, USB 3.0 Boost, SupremeFX Shielding technology, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, Disk Unlocker, ASUS Enhanced DRAM Overcurrent Protection, Preboot eXecution Environment (PXE), ASUS Stainless Steel Back I/O, ASUS Fan Xpert 2+, LANGuard, Sonic Radar II, ASUS Gamer's Guardian, AURA RGB Lighting Control
- Included Accessories
- Cable ties, I/O back plate, cable labels, 1 x M.2 screw
- Cables Included
- 2 x Serial ATA cable
- Software Included
- Drivers & Utilities, ASUS AI Charger, ASUS AI Suite III, ASUS EZ Update, Antivirus (OEM version), Media Streamer, HyStream, ASUS RAMCache, ASUS EZ Flash 3
- Plug and Play, ACPI 5.0
- 17 cm
- 17 cm
