Feel your strength on the battlefield with B150 PRO GAMING's truly immersive SupremeFX audio and experience sound so alive with realism that it hands you the vital competitive edge needed to win. With near-lossless delivery and exclusive Sonic Radar II technology to pinpoint battlefield enemies before they spot you, SupremeFX sounds stupendous - and puts both your ears and frags in front of everyone else. Only the quickest survive, so B150 PRO GAMING banishes lag - letting you annihilate your foes as fast as your trigger finger! The engineers pack in only optimal networking technology, including tournament-level Gigabit Ethernet, LANGuard and GameFirst III to keep your connection fast, so fire first and watch your enemies fall.
Flawless audio that makes you part of the game
Feel your strength on the battlefield with B150 PRO GAMING's truly immersive SupremeFX audio and experience sound so alive with realism that it hands you the vital competitive edge needed to win. With near-lossless delivery and exclusive Sonic Radar II technology to pinpoint battlefield enemies before they spot you, SupremeFX sounds stupendous - and puts both your ears and frags in front of everyone else. -
SupremeFX technology
ASUS-exclusive SupremeFX technology delivers high-fidelity, near-lossless audio no matter how frantic your game becomes. The purity and stability of the remarkable signal-to-noise ratio (SNR) is assured, with a shielded design, electromagnetic-interference (EMI) cover and voltage-protected power supply. Supreme FX's superior components maximize acoustic performance and eliminate interference. -
Illuminated red line shielding
Banish analog interference and enjoy eye-catching, customizable lighting effects. -
EMI cover
Effective shielding against electromagnetic interference preserves the integrity of audio signals for the excellent quality. -
Sonic Radar II
Sonic Radar II displays a stealthy overlay that shows what your opponents and teammates are up to on the battlefield, all managed via a simple control panel and customizable game list. See the direction and origin of key in-game sounds, and practice your enemy-pinpointing skill, plus Audio Enhancement technology clarifies every last sound - so you hear the distant sound of enemy footsteps and become the hunter, not the hunted. -
Fast protected networking
Only the quickest survive, so B150 PRO GAMING banishes lag - letting you annihilate your foes as fast as your trigger finger! The engineers pack in only optimal networking technology, including tournament-level Gigabit Ethernet, LANGuard and GameFirst III to keep your connection fast, so fire first and watch your enemies fall. -
LANGuard
ASUS LANGuard is hardware-level networking protection that employs signal-coupling technology and premium anti-EMI surface-mounted capacitors for rock-solid gaming connections and better throughout for online play, plus electrostatically guarded and surge-protected components for greater tolerance to static electricity and improved protection against surges. -
GameFirst III
Victory and defeat are separated by just milliseconds, so exclusive GameFirst III prioritizes game-related packets and allocates more bandwidth to games, eliminating laggy gameplay, streaming stutters and file-sharing slowdown - ensuring you're always the frontrunner. Choose from Optimization, Game, Media Streaming or File Sharing presets and watch your network fly. -
GPU Boost technology
Exclusive ASUS GPU Boost technology lets you accelerate your speed for extreme graphics performance safely and easily via a user-friendly interface. -
Fan Xpert 3
Via five 4/3 pin (PWM / DC) combo fan connectors and five onboard thermal sensors, Fan Xpert 3 makes sure every fan achieves optimal balance of cooling performance and low noise. -
LED control
Customizing the audio and marque LEDs is easy: just flip the switches and pick the radio buttons that match your style and gaming mood. -
Gamer's guardian for real-world protection
Protect your back in the game and let B150 PRO GAMING protect all sides in the real world! Motherboard self-protection with loads of brilliant defenses, including the unique smart DIY features ensures long-term gaming is in your future. -
Digi+ VRM
Digi+ VRM voltage-regulator module (VRM) ensures ultra-smooth and ultra-clean power delivery to the CPU at all times. -
DRAM overcurrent protection
All connection ports and DRAM are protected against overcurrent and short-circuit damage by onboard resettable fuses, extending your motherboard's life. -
Highly durable components
Fine-quality, super-tough components ensure enhanced durability The motherboard features only superior chokes, plus durable capacitors engineered to resist extreme temperature variations. -
Stainless steel back I/O
Crafted from chromium-plated, corrosion-resistant stainless steel, the input / output (I/O) panel is much longer than ordinary panels. -
Built for gaming
B150 PRO GAMING is built for play, shaped by professional gamers and intended for gaming perfection. With B150 PRO GAMING you do more than just play - you'll experience gaming on the edge of reality.
- ASUS B150 PRO GAMING - motherboard - ATX - LGA1151 Socket - B150
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel B150
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR4, non-ECC, unbuffered
- Storage Ports
- 6 x SATA-600, 1 x M.2
- USB / FireWire Ports
- 1 x USB-C + 1 x USB 3.1 + 4 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
- Max Allocated RAM Size
- 1024 MB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel B150
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
- 1024 MB
Audio
- Audio Codec
- SupremeFX
- High Definition Audio
LAN
- Network Controller
- Intel I219V
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 2 x PCIe 3.0 x1 , 1 x PCIe 3.0 x16 (x4 mode) , 2 x PCI
- Storage Interfaces
- SATA-600 / PCIe 3.0 -connectors: 6 x 7pin Serial ATA, 1 x M.2
- 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 4 x USB 3.0 , 1 x USB-C , 1 x PS/2 keyboard / mouse , 1 x VGA , 1 x USB 3.1 , 1 x HDMI , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x TOSLINK
- Internal Interfaces
- 4 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header , 1 x serial - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support
- Sleep / Wake Up
- Wake on LAN (WOL), wake on PME
- Hardware Features
- Jack retasking, ASUS Q-Design, GameFirst, ESD Guards, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, Intel Extreme Memory Profile (XMP) support, Intel Turbo Boost Technology 2.0, ASUS DIGI+ VRM, Intel Clear Video HD Technology, Fanless Design Heatsink, SupremeFX Shielding technology, AMD Quad CrossFireX technology support, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, Disk Unlocker, ASUS Enhanced DRAM Overcurrent Protection, Preboot eXecution Environment (PXE), Clear CMOS Button, ASUS Stainless Steel Back I/O, ASUS Fan Xpert 3, LANGuard, Sonic Radar II, USB 3.1 Boost
- Included Accessories
- Cable ties, I/O back plate, cable labels, 1 x M.2 screw
- Cables Included
- 4 x Serial ATA cable
- Software Included
- Drivers & Utilities, ASUS AI Charger+, ASUS AI Suite III, ASUS EZ Update, Antivirus (OEM version), Media Streamer, ASUS RAMCache, ASUS EZ Flash 3
- Plug and Play
- 30.5 cm
- 24.4 cm
