Asus AMD Radeon RX480 8GB GDDR5 PCIe3.0 Graphics Card
Quicklinx: C6P1WS00 Mfr#: RX480-8G
Radeon™ RX 480 Graphics Card
Premium VR Experiences?
Radeon™ RX 480 graphics cards with Polaris Architecture and AMD LiquidVR™ technology deliver beautifully rich and immersive VR experiences with advanced comfort and effortless compatibility with leading VR headsets.
Gamer Optimized?
Powerful Async shaders and new geometry capabilities enable unique support for DirectX® 12 and Vulkan™ in the best version of Graphics Core Next yet. Get incredibly smooth and low-latency gaming at virtually any framerate with AMD FreeSync™ technology. Stream and record your favorite games up to 4K, H.265, 60 FPS with virtually no performance impact.
  • Ready premium solutions
    Delivering extraordinary visual power and technological innovation, Radeon VR Ready Premium solutions are the industry benchmark for enabling premium experiences in the wave of high-end VR games, entertainment, and applications. Power through the most graphics-intensive games. Enjoy eye-popping cinematic visual quality. Step into fantastic virtual worlds. All with compelling VR presence, lifelike realism, and rich interactivity.
  • Intuitive performance tweaking
    Adjust clock speeds, voltages and fan speeds to tune your graphics card(s) exactly how you want to. Select between GPU Tweak's Standard or Advanced modes depending on your level of experience. Choose Standard Mode to access Intuitive options for easy tweaking. This is great for those learning how to tune graphics cards. Alternatively try out the Advanced Mode for sophisticated and extensive tuning options that enable complete control for experienced overclockers.
ASUS RX480-8G - graphics card - Radeon RX 480 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon RX 480
8 GB GDDR5
Core Clock
1266 MHz
Effective Memory Clock
8 GHz
Memory Interface
256-bit
Max Monitors Supported
4
Interfaces Details
HDMI , 3 x DisplayPort
API Supported
DirectX 12, OpenGL 4.5
3.7 cm x 24 cm x 11.2 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon RX 480
Core Clock
1266 MHz
VR Ready
4
Interfaces Details
API Supported
AMD CrossFireX Technology, HDR texture compression, Military Class 4 Components, AMD VR Ready Premium, HDCP
Size
8 GB
GDDR5 SDRAM
Effective Clock Speed
8 GHz
Bus Width
256-bit
Required Power Supply
500 W
Additional Requirements
6 pin PCI Express power connector
150 Watt
Software Included
Driver, ASUS GPU Tweak II
3.7 cm
24 cm
11.2 cm
