R9280X-DC2T-3GD5: ASUS Radeon R9 280X DirectCU II gives new edge to hardcore gamers
- DirectCU II achieves 20% lower temps with direct-contact copper heatpipes, plus 3X quieter and 6X more powerful twin 100mm fan operation.
- Exclusive CoolTech Fan drives wider airflow to keep critical components cool.
- TOP-selected 1070MHz cores run 70MHz higher than reference for smoother gameplay.
- DIGI+ VRM with 12-phase Super Alloy Power delivers precise digital power for superior efficiency, reliability, and performance.
- GPU Tweak helps you modify clock speeds, voltages, fan performance and more, all via an intuitive interface.
Game Faster. Quieter. Cooler. ASUS Exclusive Innovation
DirectCU II: 20% cooler and 3X* quieter
Exclusive DirectCU II thermal design includes a direct-GPU contact 10mm copper heatpipe and 220% larger dissipation area to boost heat removal efficiency. It performs 20% cooler and 3X quieter than reference. *Equivalent to 14dB and performance varies depending on system configuration
CoolTech Fan
Proprietary CoolTech fan consists of a hybrid blade and bearing design, with inner radial blower and outer flower-type blades. These provide multi-directional airflow to accelerate heat removal and enable highly stable graphics performance.
TOP-Selected 1070 MHz core
1070 MHz engine clock for better performance and outstanding gaming experience
DIGI+ VRM with Super Alloy Power
30% less power noise and 2.5X greater durability Acclaimed DIGI+ VRM has been applied via a 12-phase power design that uses digital voltage regulators to minimize power noise by 30%, enhance power efficiency by 15%, widen voltage modulation tolerance, and improve overall stability and longevity by 2.5 times over reference.
GPU Tweak: Real-time intuitive graphics tuning
- Shows detailed specs and actual card status with GPU-Z
- Sync GPU clocks and voltages for easier overclocking
- Monitoring widget provides real-time detailed multi-parameter info
- 2D/3D switcher locks cards in 3D mode for higher benchmarks
- Automatically checks and updates drivers and BIOS versions
- Stream on-screen action to the web in full HD
3GB GDDR5 Memory
On-board memory for the best gaming experience & the best resolution
Graphics GPU Features
- Powered by AMD Radeon™ R9 280
- AMD Eyefinity™Technology: Extend the view across up to 6displays to immerse yourself ingameplay and entertainment
- CrossFire X Support: Multi-GPU technology for extreme performance
- AMD HD3D: Immerse in stereoscopic 3D gaming and get up close and personal with your favorite stars while watching Blu-ray 3D. AMD HD3D is also designed for professionals who create complex visual effects and detailed data visualizations.
- PCI Express 3.0: Delivers double the bandwidth per lane of PCIe 2.0 for faster GPU-CPU communication.
- Microsoft DirectX 11.2 API: Brings new levels of visual realism to gaming on the PC and get top-notch performance.
I/O Ports Highlight
- 2 X Native DVI
- 1 X Native HDMI
- 1 X Native DisplayPort
- Graphics Engine: AMD Radeon R9 280X
- Bus Standard: PCI Express 3.0
- Video Memory: GDDR5 3GB
- Engine Clock: 1070 MHz
- Memory Clock: 6400 MHz ( 1600 MHz GDDR5 )
- Memory Interface: 384-bit
- Resolution: DVI Max Resolution : 2560x1600
- Interface: DVI Output : Yes x 1 (DVI-I), Yes x 1 (DVI-D), HDMI Output : Yes x 1 , Display Port : Yes x 1 (Regular DP)
- HDCP Support : Yes
- Accessories: 1 x CrossFire cable
- Software: ASUS GPU Tweak & Driver
- Dimensions: 11.2 " x 5.7 " x 1.5 " Inch
DirectCU II
Cooler and quieter Exclusive DirectCU II thermal design includes a direct-GPU contact copper heatpipe and larger dissipation area to boost heat removal efficiency. It performs cooler and quieter than reference. -
CoolTech fan
Proprietary CoolTech fan consists of a hybrid blade and bearing design, with inner radial blower and outer flower-type blades. These provide multi-directional airflow to accelerate heat removal and enable highly stable graphics performance. -
Top-selected 1070 MHz core
1070 MHz engine clock for better performance and outstanding gaming experience. -
Less power noise and greater durability acclaimed DIGI+ VRM has been applied via a 12-phase power design that uses digital voltage regulators to minimize power noise, enhance power efficiency, widen voltage modulation tolerance, and improve overall stability and longevity.
- ASUS R9280X-DC2T-3GD5 - graphics card - Radeon R9 280X - 3 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- AMD Radeon R9 280X
- Memory
- 3 GB GDDR5
- Core Clock
- 970 MHz
- Boost Clock
- 1070 MHz
- Effective Memory Clock
- 6.4 GHz
- Memory Interface
- 384-bit
- Max Resolution
- 2560 x 1600
- Interfaces Details
- DVI-I , HDMI , DVI-D , DisplayPort
- API Supported
- DirectX 11.2
- 3.81 cm x 28.4 cm x 14.5 cm
- Microsoft Certification
- Compatible with Windows 7
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 970 MHz
- Boost Clock
- 1070 MHz
- Max Resolution
- 2560 x 1600
- API Supported
- DirectX 11.2
- Native HDMI, AMD Eyefinity Technology, AMD HD3D Technology, AMD CrossFireX Technology, Super Alloy Power technology, ASUS DirectCU II Technology, ASUS DIGI+ VRM, CoolTech Fan, HDCP
- Size
- 3 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 6.4 GHz
- Bus Width
- 384-bit
- Additional Requirements
- 6-pin + 8-pin power connectors
- 300 Watt
- Cables Included
- 1 x CrossFire cable
- Software Included
- Drivers & Utilities, ASUS GPU Tweak
- 3.81 cm
- 28.4 cm
- 14.5 cm
