ASUS R7 240 delivers superb graphics performance without a single decibel of noise - just perfect for your home-theater PC (HTPC). Exclusive super alloy power components, including incredibly robust concrete-core chokes, eliminate buzzing and improving efficiency, durability and lifespan. And R7 240 is ripe to be overclocked with GPU Tweak, an easy-to-use tool from ASUS that you'll use to adjust clock speeds, voltages and more. Then, use the streaming function to share your achievements with the world.
Raging cool for the win
ASUS R7 240 delivers superb graphics performance without a single decibel of noise - just perfect for your home-theater PC (HTPC). Exclusive super alloy power components, including incredibly robust concrete-core chokes, eliminate buzzing and improving efficiency, durability and lifespan. And R7 240 is ripe to be overclocked with GPU Tweak, an easy-to-use tool from ASUS that you'll use to adjust clock speeds, voltages and more. Then, use the streaming function to share your achievements with the world. -
0 dB silent cooling
Exclusive ASUS-designed heatsinks with large surface areas effectively cool graphics cards passively so absolutely no sound is produced while running - perfect for high definition and silent home theater PCs and multimedia centers. -
Super alloy power
Exclusively-formulated alloy components boost performance by reducing power loss, enhancing durability, and achieving cooler operation. Choke concrete cores eliminate buzzing sound under full load while capacitors assure a 50,000-hour lifespan: equivalent to 2.5 times longer than traditional capacitors. -
Stream online instantly
GPU Tweak streaming tool that lets you share on-screen action in real time - so others can watch live as games are played. It's even possible to add to the streaming window scrolling text, pictures and webcam images.
- ASUS R7240-SL-2GD3-L - graphics card - Radeon R7 240 - 2 GB
- Graphics card - low profile
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- AMD Radeon R7 240
- Memory
- 2 GB DDR3
- Core Clock
- 780 MHz
- Stream Processors
- 320
- Effective Memory Clock
- 1.8 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 1920 x 1200
- DVI-D (Single-Link) , HDMI , VGA
- API Supported
- OpenCL, DirectX 11.2
- Fanless
- 4 cm x 15.7 cm x 6.9 cm
- Microsoft Certification
- Compatible with Windows 7
- Graphics card - low profile - fanless
- Bus Type
- Graphics Engine
- AMD Radeon R7 240
- Core Clock
- 780 MHz
- Stream Processors
- 320
- Max Resolution
- 1920 x 1200
- API Supported
- AMD CrossFireX Technology, AMD PowerTune technology, Super Alloy Power technology, AMD App Acceleration, AMD ZeroCore Power technology, GPU Tweak Streaming, HDCP
- Size
- 2 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1.8 GHz
- Bus Width
- 128-bit
- 75 Watt
- Included Accessories
- 2 low-profile brackets
- Software Included
- Drivers & Utilities, ASUS GPU Tweak
- 4 cm
- 15.7 cm
- 6.9 cm
