Asus AMD Radeon 5450 HD 650MHz PCI-Express 2.1 HDMI V2
Quicklinx: 8MK2WS00 Mfr#: HD5450-SL-HM1GD3-L-V2
  • ATI Radeon HD 5450
  • High-Definition Multimedia Interface (HDMI)
1 on order, delivery delayed
PLEASE NOTE: These Graphics Cards Do NOT Ship With Low Profile Brackets From April 1st 2013
Satisfy your Silent Demand of Home Entertainment with ASUS EAH5450 SILENT series
  • Silent passive cooling means true 0dB - perfect for quiet home theater PCs and multimedia centers.
  • Lowers graphics card EMI by 66% for more stable operation, clearer display, and safer computing.
  • DirectX® 11 GPU-accelerated tessellation allows more detailed geometry to be packed into a scene, allowing characters to be rendered with cinema-quality detail.
ASUS reduces 66% of electromagnetic interference both given off and received by the card - resulting in a more stable signal, clearer screen display, and a safer, healthier computing environment.
DirectX 11 GPU-accelerated tessellation allows more detailed geometry to be packed into a scene, allowing characters to be rendered with cinema-quality detail.
Graphics GPU Features
  • Powered by AMD Radeon™ HD5450
  • Software CrossFire X Support: Multi-GPU technology for extreme performance
  • AMD HD3D™ Technology: Optimize stereoscopic 3D gaming and movie-watching entertainment
  • Microsoft® Windows® 8 Ready: Enable PC users to enjoy an advanced computing experience and to do more with their PC
  • Perfect for building a hushed HTPC
    Exclusive ASUS-designed heatsinks with large surface areas effectively cool graphics cards passively so absolutely no sound is produced while running - perfect for high definition and silent home theater PCs and multimedia centers.
  • Clearer signals and safer usage
  • DirectX 11
ASUS HD5450-SL-HM1GD3-L-V2 - graphics card - Radeon HD 5450 - 1 GB
Graphics card
Bus Type
PCI Express 2.1 x16
Graphics Engine
ATI Radeon HD 5450
1 GB DDR3
Core Clock
650 MHz
Effective Memory Clock
900 MHz
Memory Interface
32-bit
Max Resolution
2560 x 1600
DVI-I , VGA , HDMI
API Supported
OpenGL, DirectX 11
Fanless
16.8 cm x 11.7 cm
Microsoft Certification
Compatible with Windows 7
Graphics card - fanless
Bus Type
PCI Express 2.1 x16
Graphics Engine
ATI Radeon HD 5450
Core Clock
650 MHz
Max Resolution
2560 x 1600
DVI-I , VGA , HDMI
API Supported
OpenGL, DirectX 11
ASUS 0-dB thermal solution, Asus EMI Shield, AMD HD3D Technology, AMD CrossFireX Technology, HDCP
Size
1 GB
DDR3 SDRAM
Effective Clock Speed
900 MHz
Bus Width
32-bit
Memory Allocation Technology
HyperMemory up to 1GB
75 Watt
Software Included
Drivers & Utilities
16.8 cm
11.7 cm
