The HD5450-SL-2GD3-L features 0 dB silent cooling and DirectX 11. Exclusive ASUS-designed heatsinks with large surface areas effectively cool graphics cards passively so absolutely no sound is produced while running - perfect for high definition and silent home theater PCs and multimedia centers. DirectX 11 GPU-accelerated tessellation allows more detailed geometry to be packed into a scene, allowing characters to be rendered with cinema-quality detail.
0 dB silent cooling
Exclusive ASUS-designed heatsinks with large surface areas effectively cool graphics cards passively so absolutely no sound is produced while running - perfect for high definition and silent home theater PCs and multimedia centers. -
DirectX 11
DirectX 11 GPU-accelerated tessellation allows more detailed geometry to be packed into a scene, allowing characters to be rendered with cinema-quality detail. -
AMD HD3D technology
Optimize stereoscopic 3D gaming and movie-watching entertainment. -
Software CrossFire X support
Multi-GPU technology is designed for extreme performance.
- ASUS HD5450-SL-2GD3-L - graphics card - Radeon HD 5450 - 2 GB
- Graphics card
- Bus Type
- PCI Express 2.1 x16
- Graphics Engine
- ATI Radeon HD 5450
- Memory
- 2 GB DDR3
- Core Clock
- 650 MHz
- Effective Memory Clock
- 900 MHz
- Memory Interface
- 64-bit
- Max Resolution
- 2560 x 1600
- DVI-D (dual link) , VGA , HDMI
- API Supported
- DirectX 11
- Fanless
- 16.8 cm x 11.7 cm
- Microsoft Certification
- Compatible with Windows 7
- Graphics card - fanless
- Bus Type
- Graphics Engine
- Core Clock
- 650 MHz
- Max Resolution
- 2560 x 1600
- API Supported
- DirectX 11
- ASUS 0-dB thermal solution, Asus EMI Shield, AMD HD3D Technology, AMD CrossFireX Technology, HDCP
- Size
- 2 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 900 MHz
- Bus Width
- 64-bit
- 75 Watt
- Software Included
- Drivers & Utilities
- 16.8 cm
- 11.7 cm
