This motherboard supports remote wake with the onboard Intel LAN, so you can connect with your PC from anywhere in the world. You will be able to power your PC on or turn it off, monitor and take control of it remotely with another smartphone, tablet or computer.
Purity Sound is a combination of several hardware, software audio solutions and technologies that will satisfy even the pickiest audiophiles. Including 7.1 CH HD audio with Realtek ALC1150 audio codec, 115 dB SNR DAC with Differential Amplifier, TI 5532 Premium Headset Amplifier which supports up to 600 ohm headphones, cap less Direct Drive technology, EMI shielding cover, PCB isolate shielding and support for DTS Connect.
Intel Ethernet
This motherboard supports remote wake with the onboard Intel LAN, so you can connect with your PC from anywhere in the world. You will be able to power your PC on or turn it off, monitor and take control of it remotely with another smartphone, tablet or computer. -
Purity Sound
Purity Sound is a combination of several hardware, software audio solutions and technologies that will satisfy even the pickiest audiophiles. Including 7.1 CH HD audio with Realtek ALC1150 audio codec, 115 dB SNR DAC with Differential Amplifier, TI 5532 Premium Headset Amplifier which supports up to 600 ohm headphones, cap less Direct Drive technology, EMI shielding cover, PCB isolate shielding and support for DTS Connect. -
HDMI-in
Tired of constantly switching devices to connect to your one and only monitor? From now on just connect the monitor to your motherboard, and connect your secondary device (such as a PS3 or Xbox) to the motherboard's HDMI-In port. With HDMI-In users may conveniently toggle between the computer's screen and the secondary device's screen, or even use their secondary device without powering on the computer. -
More precise, more efficient
By adopting digital pulse-width modulation (PWM), the ASRock motherboard can provide CPU Vcore voltage more efficiently and smoothly. Compared to analog PWM, digital PWM can optimize the CPU power solution and provide a proper and stable Vcore for the processor. -
12 power phase design
Designed with a 12 power phase design, this motherboard features sturdy components and completely smooth power delivery to the CPU. Plus, it offers unmatched overclocking capabilities and enhanced performance with the lowest temperature for advanced gamers as well. -
Dual-Stack MOSFET (DSM)
Dual-Stack MOSFET (DSM) is an excellent design of MOSFETs. The silicon die area is increased by stacking two dies into a MOSFET. The larger the die area, the lower Rds (on). Compared to traditional discrete MOSFET, DSM can provide larger die area and lower Rds (on), so the power supply for CPU Vcore is more efficient. -
Intel Dual Gigabit LAN
Dual LAN with Teaming function enabled on this motherboard allows two single connections to act as one single connection for twice the transmission bandwidth, making data transmission more effective. -
Triple monitor
This motherboard supports Triple Monitor. You may choose up to three display interfaces to connect monitors and use them simultaneously. -
Distortion-free slot
ASRock's pin design for the memory slots may appear to be the same as former designs, but actually effectively reduces distortion and promotes performance, because they strive for perfection even in the most trivial details. -
Front USB 3.0 panel
This motherboard comes with a front USB 3.0 panel which not only provides connection for 2 USB 3.0 ports but also serves as a 2.5" HDD/SDD rack. -
XFast 555
ASRock's unique XFast 555 technology (XFast RAM, XFast LAN and XFast USB) allows users to experience 5 times performance boost in terms of system performance, LAN speed and USB transfer speed. -
FAN-tastic tuning
Configure different fan speeds for respective temperatures using the graph. The fans will automatically shift to the next speed level when the assigned temperature is met. -
Easy driver installer
For users that don't have an optical disk drive to install the drivers from support CD, easy driver installer is a handy tool in the UEFI that installs the LAN driver to your system via an USB storage device, then downloads and installs the other required drivers automatically.
- ASRock Z87 Extreme6 - motherboard - ATX - LGA1150 Socket - Z87
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z87 Express
- Processor Socket
- 1 x LGA1150 Socket
- Compatible Processors
- Pentium, Celeron, Xeon, Core i5, Core i3, Core i7
- Max RAM Size
- 32 GB
- RAM Supported
- 4 DIMM slots - DDR3, non-ECC, unbuffered
- Storage Ports
- 6 x SATA-600 (RAID), 4 x SATA-600, 1 x eSATA-600
- USB / FireWire Ports
- 4 x USB 3.0 + 2 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
- Max Allocated RAM Size
- 1792 MB
- Audio
- HD Audio (8-channel)
- LAN
- 2 x Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z87 Express
- Processor Socket
- LGA1150 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR3
- Bus Clock
- 2400 MHz, 1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz, 2133 MHz, 2800 MHz, 2933 MHz
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
- 1792 MB
Audio
- Audio Codec
- Realtek ALC1150
- High Definition Audio
LAN
- Network Controller
- Intel I211-AT / I217V
- Network Interfaces
- Expansion Slots
- 1 x CPU , 4 x DIMM 240-pin , 3 x PCIe 3.0 x16 (dual: x8 mode; triple: x8, x4, x4 mode; single card: x16 mode) , 1 x PCIe 2.0 x1 , 1 x Mini PCIe , 2 x PCI
- Storage Interfaces
- SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , ASMedia ASM1061: SATA-600 -connectors: 4 x 7pin SATA, 1 x 7pin eSATA - 4 devices
- RAID Features
- Intel Rapid Storage Technology
- 1 x PS/2 keyboard / mouse , 1 x DVI-I , 2 x HDMI , 1 x DisplayPort , 1 x TOSLINK , 2 x USB 2.0 , 4 x USB 3.0 , 2 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
- Internal Interfaces
- 2 x USB 3.0 - header , 2 x USB 2.0 - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- SMBIOS 2.3.1. support, ACPI 1.1 support, UEFI BIOS
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage, power supply fan tachometer
- Sleep / Wake Up
- Wake on LAN (WOL)
- Hardware Features
- ASRock Hybrid Booster, ASRock U-COP, NVIDIA SLI Technology Support, 12 Phase Power Design, ASRock Instant Flash, ASRock CPU Frequency Stepless Control, ASRock Boot Failure Guard (B.F.G.), Teaming Technology, HDCP compliant, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, ASRock APP Charger, Intel Turbo Boost Technology 2.0, ASRock Good Night LED, Intel Clear Video HD Technology, ASRock XFast USB, Intel Smart Response Technology, Conductive Polymer Capacitors, ASRock XFast LAN, ASRock XFast RAM, ASRock Crashless BIOS, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support, ASRock OMG (Online Management Guard), ASRock Internet Flash, Digi Power Design, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, ASRock Dehumidifier Function, Dual-Stack MOSFET (DSM), ASRock Interactive UEFI, ASRock Fast Boot, ASRock Restart to UEFI, ASRock UEFI System Browser
- Included Accessories
- I/O back plate, rear USB 3.0 bracket, ASRock SLI_Bridge_2S Card, front USB 3.0 panel with 2.5" HDD/SSD rack
- Cables Included
- 6 x Serial ATA cable
- Software Included
- Drivers & Utilities, Cyberlink MediaEspresso 6.5 (30-day trial)
- WHQL, FCC, EuP Ready, ErP Ready
