Your basket is empty
Apple AirPort Extreme Base Station
Quicklinx: 7TB7WS00 Mfr#: MD031B/A
Protocol: IEEE 802.11a
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
  • IEEE 802.11a
5 on order, delivery delayed
£106.31 ex VAT
£127.57 inc VAT
Free delivery available
Introducing the AirPort Extreme Base Station. The AirPort Extreme is the perfect wireless solution for home, school, and business. As it blankets your space with a blazing-fast, secure wireless network, it opens up a world of possibilities for home entertainment, sharing files, printing, and more.
Surf the web, chat, send email, or exchange photos from any computer or from your phone. Print or access a shared hard drive - wirelessly. Set limits for when your kids can access the Internet. Secure your network with a firewall and strong encryption. Even use AirPort Extreme as the perfect companion to Apple TV.
Apple AirPort Extreme Base Station - radio access point
Radio access point
Enclosure Type
External
16.5 cm x 16.5 cm x 3.4 cm
0.75 kg
United Kingdom
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, PPPoE, DHCP, DNS, Bonjour
Remote Management Protocol
SNMP, HTTP
Frequency Band
2.4 GHz, 5 GHz
Connection / user qty : 50
Firewall protection, DHCP support, NAT support, MAC address filtering, IPv6 support, VPN passthrough, MIMO technology, DNS proxy
Apple MacOS X 10.5.7 or later, Microsoft Windows Vista SP1, Microsoft Windows XP SP3, Microsoft Windows 7 SP1
1 year warranty
Radio access point
16.5 cm
16.5 cm
3.4 cm
0.75 kg
United Kingdom
External
Wireless
SNMP, HTTP
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Status
Encryption Algorithm
LEAP, 128-bit WEP, 40-bit WEP, TLS, PEAP, TTLS, WPA, WPA2
Authentication Method
RADIUS, EAP-FAST
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11n
Aerial
Antenna
Internal integrated
1 x Hi-Speed USB - 4 PIN USB Type A , 1 x network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45 ( WAN ) , 3 x network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45
UL 60950, EN 300.328, FCC Part 15 B, RSS-210, AS/NZS 4268, CSA C22.2 No. 60065, EN 301.893, ARIB STD-T66, RCR STD-33
Power adapter - external
1 year warranty
Service & Support Details
Limited warranty - 1 year
35 °C
20 - 80%
Used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 90 day warranty and is in good working order. You can find out the exact details about each product using the key below.
Accessories Packaging Functional Software Manuals
Ref: 7TB7 009381
Condition: Item has been used.
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £49.47
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Compatibility: Mac
Compatibility: PC
Brand: Apple
Stock Status: Used Stock
Price Range Ex VAT: 100 - 150
