APC award-winning Smart-UPS is the most popular UPS in the world for servers, storage and networks. Trusted to protect critical data and equipment from power problems by supplying clean and reliable network-grade power. In addition to legendary reliability and manageability, Smart-UPS have extremely high efficiency at low, medium and high load levels making them ideal for today's multi-core or virtualized servers that have varying load consumption. Available in a variety of form factors, there is a model for every application and budget.
- APC Smart-UPS 750 LCD - UPS - 500 Watt - 750 VA
- UPS - external
- 13.8 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V ( 57 - 63 Hz )
- Power Capacity
- 500 Watt / 750 VA
- Output Connector(s)
- 6 x power IEC 320 EN 60320 C13
- Battery
- Lead Acid
- Run Time (Up To)
- 5 min at full load
- Networking
- RS-232, USB
- 13.7 cm x 35.8 cm x 15.7 cm
- 3 years warranty
- UPS - external
- UPS Technology
- Line interactive
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 160 - 285 V
- Input Voltage Range (Adjustable)
- AC 151 - 302 V
- Frequency Required
- 50/60 Hz
- Input Connector(s)
- Power IEC 320 EN 60320 C14
- Power Output Connectors Details
- Output Voltage
- Power Capacity
- 500 Watt / 750 VA
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 340 Joules
- Technology
- Lead Acid
- Run Time (Up To)
- Remote Management Interface
- RS-232, USB
- 1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x USB
- Expansion Slot(s)
- 1 SmartSlot
- Audible alarm, LCD display
- C-Tick, GOST, UL 1449, VDE, EN 50091-2, EN 50091-1
- 3 years warranty
- Service & Support Details
- Limited warranty - 3 years , Limited warranty - batteries - 2 years
- 13.7 cm
- 35.8 cm
- 15.7 cm
- 13.8 kg
Options (3)
| APC Network Management Card With 2 Environment Monitor | In Stock | £243.90 |
| APC UPS Network Management Card 2 | In Stock | £150.72 |
| APC APC Legacy Communications Card | Out of Stock | £28.79 |
