Your basket is empty
APC RackPDU Metered ZeroU 16A 230V
Quicklinx: 50K3WS00 Mfr#: AP7851
APC's Metered Rack Power Distribution Units (PDUs) provide power distribution as well as equips on-site installers with the ability to monitor the aggregate current draw as equipment is connected to the unit. These Metered Rack PDUs also have alarm thresholds that when exceeded provide alarms to alert users of potential problems. These features help eliminate the possibility of an overloaded circuit.
APC Metered Rack PDU Zero U - power distribution strip
Power distribution strip - rack-mountable
4.3 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Output Connector(s)
4 x power IEC 320 EN 60320 C19 , 20 x power IEC 320 EN 60320 C13
Ethernet 10/100
Remote Management Protocol
SNMP, Telnet, HTTP
Microsoft Windows NT 4.0, Microsoft Windows 98/2000/XP
5.6 cm x 4.4 cm x 161.9 cm
2 years warranty
Input Voltage
AC 230 V
Input Voltage Margin
± 10%
Input Connector(s)
1 x power IEC 309
Output Voltage
AC 230 V
Max Electric Current
16 A
Remote Management Interface
Ethernet 10/100
SNMP, Telnet, HTTP
1 x LAN - RJ-45 , 1 x serial - RJ-11
1 x power cable - integrated - 91.4 cm , 1 x serial cable - external
Rack Mounting Kit
Included
LCD display, LED display
C-Tick, EN 60950, IEC 61000-3-2, IEC 61000-3-3, VDE, IEC 60950, EN55024, EN55022 Class A
Software Included
Drivers & Utilities
2 years warranty
Service & Support Details
-5 °C
45 °C
Min Storage Temperature
-25 °C
Max Storage Temperature
65 °C
5 - 95%
Humidity Range Storage
5 - 95%
5.6 cm
4.4 cm
161.9 cm
4.3 kg
