The Back-UPS Pro provides abundant battery backup power, so you can work through medium and extended length power outages. It safeguards your equipment against damaging surges and spikes that travel along utility and data lines. The Back-UPS Pro also features automatic voltage regulation (AVR), which instantly adjusts high and low voltages to safe levels, so you can work indefinitely during brownouts and overvoltages.
The Back-UPS Pro also includes unique "green" features, automatically turn off idle peripherals. A high efficiency charging system and "AVR Bypass" also reduce power consumption. With the rest of the Back-UPS Pro's standard features, this is the perfect unit to protect your productivity from the constant threat of bad power and lost data.
Includes: CD with software, Qty 2 - Detachable 2.0 m IEC power cords, Telephone Cable, USB cable, User Manual, Warranty card
- APC Back-UPS Pro 1500 - UPS - 865 Watt - 1500 VA
- UPS - external
- 13.4 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V ( 50/60 Hz )
- Power Capacity
- 865 Watt / 1500 VA
- Output Connector(s)
- 5 x power IEC 320 EN 60320 C13 ( surge ) , 5 x power IEC 320 EN 60320 C13 ( UPS and surge )
- Battery
- Lead Acid
- Batteries Qty
- 1
- Networking
- RS-232, USB
- 11.2 cm x 38.1 cm x 30.2 cm
- 2 years warranty ( European Union - 3 years )
- UPS - external
- Black
- Input Voltage
- AC 230 V
- Frequency Required
- 50/60 Hz
- Input Connector(s)
- Power IEC 320 EN 60320 C14
- Power Output Connectors Details
- Output Voltage
- Power Capacity
- Dataline Surge Protection
- Network - RJ-45 , Phone line - RJ-11
- Output Waveform
- Stepped approximation to a sinewave
- Surge Suppression
- Quantity
- 1
- Technology
- Lead Acid
- Remote Management Interface
- RS-232, USB
- Cables Included
- 1 x power cable - external - 1.8 m
- Audible alarm, LCD display, Automatic Voltage Regulation (AVR)
- GOST, GS, NEMKO, RoHS
- Software Included
- Drivers & Utilities, APC PowerChute Personal Edition
- Service & Support Details
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 11.2 cm
- 38.1 cm
- 30.2 cm
- 13.4 kg
- Shipping Width
- 23.8 cm
- Shipping Depth
- 48.9 cm
- Shipping Height
- 38.2 cm
- Shipping Weight
- 14.5 kg
