Lightning and power surges can permanently ruin your electronic equipment. Changes in voltage cause lockups and loss of work. This unit will protect your equipment from the threat of bad power. The Essential SurgeArrest series offers a great value for home equipment and business applications such as small office/home computers.
Transformer Block Spacing
Connect bulky transformer block plugs without covering up other outlets -
Manual disconnect switch
Enables the surge supressor to be de-energized for service without disconnecting the protected load -
Right Angle Plug
Plug angle allows for equipment and furniture to be placed closer to the wall than with a standard power cord. Reduces cord stress too -
180 degree Rotating Cord Retainer
A 180-degree rotating cord with strain relief offers flexibility in positioning the SurgeArrest, and in routing the power cord -
Outlets
Enough outlets for your game console, TV and four other electronic devices. Protection from surges, spikes and even lightning is guaranteed
- APC SurgeArrest Essential - surge protector
- Surge protector - external
- 0.7 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 230 V
- Input Connectors
- 1 x power BS 1363
- Output connectors
- 5 x power BS 1363
- Charcoal
- 7 cm x 4.5 cm x 38.5 cm
- Limited lifetime warranty
- Charcoal
- Localisation
- United Kingdom
- Input Voltage
- AC 230 V
- Frequency Required
- 50/60 Hz
- Input Connectors
- 1 x power BS 1363
- Power Output Connectors Details
- 5 x power BS 1363
- Max Electric Current
- 13 A
- Dataline Surge Protection
- Cable TV - RCA
- Surge Suppression
- Surge Energy Rating
- 960 Joules
- EMI/RFI Noise Filtration
- 30 dB
- Circuit Protection
- Circuit breaker
- Cables Included
- Power cable - integrated - 1.8 m , Coaxial RF cable - external - 1.8 m
- UL 1449
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 0 - 95%
- 7 cm
- 4.5 cm
- 38.5 cm
- 0.7 kg
