Lightning and power surges can permanently ruin your electronic equipment. Changes in voltage cause lockups and loss of work. This unit will protect your equipment from the threat of bad power. The Essential SurgeArrest series offers a great value for home equipment and business applications such as small office/home computers.
Transformer Block Spacing
Connect bulky transformer block plugs without covering up other outlets -
Always on Outlets
8 outlet models offer dedicated space to accommodate wide transformer blocks without covering adjoining outlets and 2 always on outlets. You can plug 8 power cords including 3 transformers at the same time. In case you have equipment that has to stay on all the time, such as fax machine, you can plug it in always on outlets. The equipment will be protected and will have power supply even when the unit is switched off
- APC Essential Surgearrest - surge protector
- Surge protector - external
- 0.1 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 230 V
- Input Connectors
- 1 x power BS 1363
- Output connectors
- 1 x power BS 1363
- Charcoal
- 7 cm x 9.4 cm x 7.6 cm
- Limited lifetime warranty
- Charcoal
- Localisation
- United Kingdom
- Input Voltage
- AC 230 V
- Frequency Required
- 50/60 Hz
- Input Connectors
- 1 x power BS 1363
- Power Output Connectors Details
- 1 x power BS 1363
- Max Electric Current
- 10 A
- Surge Suppression
- Surge Energy Rating
- 960 Joules
- EMI/RFI Noise Filtration
- 20 dB
- UL 1449
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 0 - 95%
- 7 cm
- 9.4 cm
- 7.6 cm
- 0.1 kg
