The Back-UPS ES offers affordable battery backup and surge protection for home computers. With enough power outlets to protect your entire system, built-in phone/fax/modem line (DSL compatible) protection and easy-to-install safe system shutdown software all make this power protection solution the best value for home and home office computers.
- APC Back-UPS ES 550 - UPS - 330 Watt - 550 VA
- UPS - external
- 5.9 kg
- Input Voltage
- AC 120 V
- Output Voltage
- AC 120 V ( 60 Hz )
- Power Capacity
- 330 Watt / 550 VA
- Output Connector(s)
- 4 x power NEMA 5-15 ( surge ) , 4 x power NEMA 5-15 ( UPS and surge )
- Battery
- Lead Acid
- Battery Form Factor
- Internal
- Batteries Qty
- 1
- Run Time (Up To)
- 3.2 min at full load
- Networking
- USB
- 30.5 cm x 17.8 cm x 8.4 cm
- 3 years warranty
- UPS - external
- Battery Enclosure Type
- Internal
- Black
- UPS Technology
- Off-line
- Input Voltage
- AC 120 V
- Input Voltage Range
- AC 88 - 139 V
- Frequency Required
- 60 Hz
- Input Connector(s)
- 1 x power NEMA 5-15
- Power Output Connectors Details
- Output Voltage
- Power Capacity
- 330 Watt / 550 VA
- Dataline Surge Protection
- Phone line - RJ-11
- Output Waveform
- Stepped approximation to a sinewave
- Surge Suppression
- Surge Energy Rating
- 365 Joules
- Circuit Protection
- Circuit breaker
- Quantity
- 1
- Technology
- Lead Acid
- Run Time (Up To)
- Recharge Time
- 24 hours
- Remote Management Interface
- USB
- 1 x management (USB)
- Cables Included
- 1 x power cable - 1.8 m , 1 x USB cable
- Equipment Protection Value
- 75000 US Dollars
- Audible alarm, LED indicators
- cUL, NOM, UL 1778, UL 497A, UL 497B, FCC Part 15 B, FCC Part 68, RoHS
- 3 years warranty
- Service & Support Details
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 5 - 95%
- Sound Emission
- 45 dBA
- 30.5 cm
- 17.8 cm
- 8.4 cm
- 5.9 kg
- Shipping Width
- 43.8 cm
- Shipping Depth
- 14 cm
- Shipping Height
- 24.1 cm
- Shipping Weight
- 6.5 kg
