Battery Backup Power and Surge Protection for Computers and Electronics The Back-UPS 700 from APC by Schneider Electric powers your computer and electronic equipment during storms and outages. The BX700U-GR features Automatic Voltage Regulation (AVR). This feature instantly adjusts high and low voltage fluctuations to safe levels for connected electronics, saving battery power for when you need it most during storms and outages. Equipped with 3 French sockets, the 700 keeps your desktop computer, monitor or other critical devices (router, modem, television, etc.) running when the power goes out. Specifically designed for electronic equipment in harsh power environments, the Back-UPS 700 maximizes productivity and work efficiency while providing critical power during emergencies. critical power during emergencies.
Automatically steps up low voltage and steps down high voltage to levels that are suitable for your equipment -
USB connection
Use your PC to access additional power protection and management features for your UPS via a USB Port -
Telephone dataline surge protection
Provides protection of connected equipment from power surges traveling on telephone lines
- APC Back-UPS 700VA - UPS - 390 Watt - 700 VA
- UPS - external
- 6 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V
- Power Capacity
- 390 Watt / 700 VA
- Input Connectors
- 1 x power IEC 60320 C13
- Output connectors
- 4 x power IEC 60320 C14 (UPS and surge)
- Battery
- Lead Acid
- Batteries Qty
- 1
- Run Time (Up To)
- 1 min at full load
- Networking
- USB
- Black
- 11.5 cm x 25.6 cm x 20 cm
- 2-year warranty
- UPS - external
- Black
- UPS Technology
- Line interactive
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 150 - 280 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V 50/60 Hz
- Power Capacity
- 390 Watt / 700 VA
- Dataline Surge Protection
- Phone line - RJ-11
- Output Waveform
- Stepped approximation to a sinewave
- Surge Suppression
- Surge Energy Rating
- 273 Joules
- Circuit Protection
- Circuit breaker
- Quantity
- 1
- Technology
- Lead Acid
- Run Time (Up To)
- 1 min at full load , 9 min at half load
- Recharge Time
- 6 hours
- Maintenance free, sealed, leak-proof
- Remote Management Interface
- USB
- 1 x management (USB) - 4 pin USB Type B
- Cables Included
- Power cable 1.22 m
- Audible alarm, audible alarm, Automatic Voltage Regulation (AVR), LED indicators, automatic self-test
- RoHS, REACH
- Software Included
- APC PowerChute Personal Edition
- Limited warranty - replace or repair - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 45 dBA
- 11.5 cm
- 25.6 cm
- 20 cm
- 6 kg
- Shipping Width
- 29.5 cm
- Shipping Depth
- 34 cm
- Shipping Height
- 27.5 cm
- Shipping Weight
- 6.5 kg
APC Replacement Battery Cartridge #110 | In Stock | £53.11 |
