The Back-UPS battery backup offers guaranteed power and surge protection for wireless networks, computers, gaming consoles and other electronics in your home or business. The supply battery backup during outages and unsafe voltage fluctuations, as well as provide protection from damaging surges and spikes. It is the perfect choice to protect your data and keep you connected.
Audible alarms
Provides notification of changing utility power and UPS power conditions -
Automatic self-test
Periodic battery self-test ensures early detection of a battery that needs to be replaced -
Intelligent battery management
Maximizes battery performance, life, and reliability through intelligent, precision charging -
Replace Battery LED
An external Replace Battery LED informs the end-user that the battery needs to be replaced -
Cold-start capable
Provides temporary battery power when the utility power is out -
Battery failure notification
Provides early-warning fault analysis on batteries enabling timely preventive maintenance -
Resettable circuit breaker
Easy recovery from overloads; no need to replace a fuse -
Disconnected battery notification
Warns when a battery is not available to provide backup power -
Adjustable voltage sensitivity
Provides the ability to adapt the UPS for optimal performance in specific power environments or generator applications -
Overload protection
Safeguards unit from damage by automatically turning it off in the event of a short circuit or overload -
Automatic Voltage Regulation (AVR)
Automatically steps up low voltage and steps down high voltage to levels that are suitable for your equipment
- APC Back-UPS 1100 - UPS - 660 Watt - 1100 VA
- UPS - external
- 12 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V
- Power Capacity
- 660 Watt / 1100 VA
- Input Connectors
- 1 x power IEC 60320 C14
- Output connectors
- 6 x power IEC 60320 C13 (UPS and surge)
- Battery
- Lead Acid - 7.2 Ah
- Batteries Qty
- 2
- Run Time (Up To)
- 2 min at full load
- Black
- 13 cm x 33.6 cm x 21.5 cm
- 2-year warranty
- UPS - external
- Black
- UPS Technology
- Line interactive
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 150 - 280 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V 50/60 Hz
- Max Electric Current
- 5 A
- Power Capacity
- Output Waveform
- Stepped approximation to a sinewave
- Surge Suppression
- Surge Energy Rating
- 273 Joules
- Circuit Protection
- Circuit breaker
- Quantity
- 2
- Technology
- Lead Acid
- Voltage Provided
- 12 V
- Capacity
- 7.2 Ah
- Run Time (Up To)
- 2 min at full load , 11 min at half load
- Recharge Time
- 8 hours
- Cables Included
- Power cable - external - 1.2 m
- Audible alarm, audible alarm, Automatic Voltage Regulation (AVR), LED indicators, overload protection, short-circuit protection
- RoHS, REACH
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 45 dBA
- 13 cm
- 33.6 cm
- 21.5 cm
- 12 kg
- Shipping Width
- 24.5 cm
- Shipping Depth
- 44 cm
- Shipping Height
- 29.5 cm
- Shipping Weight
- 12.92 kg
