APC's Switched Rack Power Distribution Units (PDUs) are premium solutions to many of the power management problems seen in today's IT environments. Some of the problems are unauthorized use of power outlets, locked-up equipment, in-rush current, overloaded circuits, and the need of remote access to power outlets in the rack. The Switched Rack PDUs address these problems through individual outlet control, power on and off delays, current monitoring, alarm thresholds, and network management. Individual outlet control allows users to turn outlets on, turn outlets off, or recycle power to equipment, which can reboot locked-up equipment and avoid unauthorized use of outlets. Power delays allow users to determine the order in which equipment is powered up or down. Utilizing the power delay feature will avoid in-rush current, which can cause overloads. Monitoring the current draw at the rack level is key to avoiding downtime due to overloaded circuits. The Switched Rack PDUs provide an aggregate current draw, which can be viewed remotely or locally, via digital display. In addition, alarms will be generated based on user-defined thresholds to alert users of potential circuit overloads.
Network management
Full-featured network management interfaces that provide standards-based management via Web, SNMP and Telnet. Allows users to access, configure, and manage units from remote locations to save valuable time. Associated with this feature is the ability to quickly and easily upgrade the firmware via network download to installed units for future product enhancements. -
Remote individual outlet control
Remotely manage outlets so users can turn outlets off that are not in use or recycle power to locked-up equipment. -
Power delays
Allows users to configure the sequence in which power is turned on or off for each outlet. This helps avoid in-rushes at start-up, which can cause overloaded circuits and dropped loads. Sequencing also allows users to predetermine which piece of equipment is turned on first so other equipment dependant on that unit will function properly. -
Load indicator LED
This indicates overload and warning conditions based on the user-defined alarm thresholds, and alerts users of potential overloaded circuits. -
Integrates with InfraStruXure Central
An IT-ready, scalable monitoring system that collects, organizes, and distributes critical alerts, surveillance video and key information, providing a unified view of complex physical infrastructure environments from anywhere on the network.
- APC Switched Rack PDU - power distribution strip
- Power distribution strip - external
- Rack Size
- 19" - 1U
- 2.3 kg
- Input Voltage
- AC 208/230 V
- Output Voltage
- AC 208/230 V
- Input Connectors
- 1 x power IEC 60320 C20
- Output connectors
- 8 x power IEC 60320 C13
- Networking
- Ethernet 10/100
- Remote Management Protocol
- SNMP, Telnet, HTTP
- Black
- System Requirements
- Microsoft Windows NT 4.0, Microsoft Windows 98/2000/XP
- 44.5 cm x 10.8 cm x 4.5 cm
- 2-year warranty
- Designed For
- P/N: AR3100, AR3150, SMX3000RMHV2UNC, SU2200RMI3U.1, SU2200RMXLI3U-3EW, SU2200RMXLINET-3EW, SU3000RMINET-3EW, SU3000RMXLI3U-3EW, SU5000RMI5U-3EW, SU5000RMXLI5U-3EW, SUA2200RMXLI3U, SUA3000I, SUA3000R2IX322, SUA3000RMI, SURT3000XLI/S, SURT3000XLI-BRZ, SURT3000XLI-GLD, SURT3000XLI-SLV, SURT3000XLI-TU
- Height (Rack Units)
- 1U
- Rack Size
- 19"
- Black
- Input Voltage
- AC 208/230 V
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 208/230 V
- Max Electric Current
- 16 A
- Remote Management Interface
- Ethernet 10/100
- 1 x LAN - RJ-45 , 1 x serial - RJ-12
- Cables Included
- Power cable - external - 2.5 m , Serial cable - external
- Rack Mounting Kit
- Included
- LCD display, LED display
- FCC Class A certified, UL, VCCI, C-Tick, cUL, ICES-003, IEC 61000-3-2, IEC 61000-3-3, VDE, EN55024, EN55022 Class A
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - 2 years
- 0 °C
- 45 °C
- Min Storage Temperature
- -25 °C
- Max Storage Temperature
- 65 °C
- 0 - 95%
- Humidity Range Storage
- 0 - 95%
- 44.5 cm
- 10.8 cm
- 4.5 cm
- 2.3 kg
- Designed For
- P/N: AR3100, AR3150, SMX3000RMHV2UNC, SU2200R3IBX120, SU2200RMI3U.1, SU2200RMXLI3U, SU2200RMXLI3U-1EW, SU2200RMXLI3U-2EW, SU2200RMXLI3U-3EW, SU2200RMXLINET-1EW, SU2200RMXLINET-2EW, SU2200RMXLINET-3EW, SU3000R3IBX120, SU3000RMINET, SU3000RMINET-1EW, SU3000RMINET-2EW, SU3000RMINET-3EW, SU3000RMTX136, SU3000RMXLI3U, SU3000RMXLI3U-1EW, SU3000RMXLI3U-2EW, SU3000RMXLI3U-3EW, SU5000R51BX120, SU5000R5IBX120, SU5000R5TBX135, SU5000RMI5U, SU5000RMI5U-1EW, SU5000RMI5U-2EW, SU5000RMI5U-3EW, SU5000RMXLI5U, SU5000RMXLI5U-1EW, SU5000RMXLI5U-2EW, SU5000RMXLI5U-3EW, SUA2200RMI2U-1EW, SUA2200RMI2U-SLV, SUA2200RMXLI3U, SUA3000I, SUA3000R2IX322, SUA3000RMI, SUA3000RMI2U, SUA3000RMI2U-1EW, SUA3000RMI2U-2EW, SUA3000RMI2U-3EW, SUA3000RMI2U-BRZ, SUA3000RMI2U-GLD, SUA3000RMI2U-SLV, SURT3000XLI, SURT3000XLI/S, SURT3000XLI-BRZ, SURT3000XLI-GLD, SURT3000XLI-SLV, SURT3000XLI-TU
