AOC E970SWN 18.5" 1366x768 5ms VGA LED Black Monitor
Quicklinx: 8YJVWS00 Mfr#: E970SWN
The e970Swn offers great image quality at 1366 x 768 resolution. The 19-inch class monitor is EPEAT Silver and ENERGY STAR certified. Slim in design with extra narrow bezel and 20M: 1 contrast ratio.
  • Kensington Lock
    Kensington Lock is an anti-theft system, comprising a metal-reinforced hole in the body of the respective device, to use with a metal cable secured with a key/lock system. Kensington locks enable you to secure your AOC monitor during a LAN event, an organisation, or wherever you carry it.
  • Vesa Mount
    AOC's Ergo Base stands bring versatility, sturdiness and ease of use in one package. But do you still want to use your wall mount or multi-monitor setup using desk mounts? VESA mounts bring you the uppermost flexibility. Upside-down, in pivot mode, on top of each other, attach your monitor wherever you want using 3rd party mounts and stands thanks to the VESA mount option.
AOC E970SWN - LED monitor - 18.5"
LED-backlit LCD monitor - 18.5"
Aspect Ratio
Widescreen
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m2
Contrast Ratio
20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
43.74 cm x 15.6 cm x 33.68 cm - with stand
2.15 kg
Environmental Standards
ENERGY STAR Qualified , EPEAT Silver
C-Tick, BSMI, CCC, FCC, RoHS, ISO 9241-307, cTUVus, CECP, EPA, DDC-2B/CI
3 years warranty
VESA
Display Type
Diagonal Size
18.5"
Aspect Ratio
Widescreen
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m2
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
LED backlight
2.15 kg
VGA
Mechanical
Tilt
Tilt Angle
-3/+10
Flat Panel Mount Interface
100 x 100 mm
AC 120/230 V ( 50/60 Hz )
15 Watt
Power Consumption Stand by
0.5 Watt
EPEAT Compliant
EPEAT Silver
3 years warranty
Service & Support Details
Limited warranty - 3 years
