This model is characterized by the display technology with LED backlights, a top performance and a timelessly classic, black design. Due to high contrast and brightness values as well as a quick response time, the monitor renders even the fastest movie sequences fluently and razor-sharp. At its slimmest region, this elegant display, which sports hairline textures on the rear side as well as the base, is just 1.6 cm deep. Thanks to numerous features it is recommended for both office and home.
Three-Year Warranty
AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge. Read the complete AOC warranty statement for more information.
- AOC Value e950Swdak - LED monitor - 18.5"
- LED-backlit LCD monitor - 18.5"
- Aspect Ratio
- 16:9
- Native Resolution
- 1366 x 768 at 60 Hz
- Pixel Pitch
- 0.3 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Voltage
- AC 90 - 240 V (50/60 Hz)
- 44.435 cm x 17.5 cm x 34.2 cm
- 2.63 kg
- Environmental Standards
- ENERGY STAR Qualified
- GOST, FCC, RoHS, EuP
- 3-year warranty
- Display Type
- Diagonal Size
- 18.5"
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.3 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 80 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- HDCP, Eco-Mode, e-Saver technology
- 2.63 kg
Audio
- Speakers
- VGA , DVI-D
Mechanical
- VESA Mounting Interface
- 75 x 75 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x audio cable
- Input Voltage
- Power Consumption (Typical)
- 12 Watt
- Power Consumption Stand by
- 0.3 Watt
- Included Software
- Screen+, I-Menu
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £11.38 |
