AOC E2250SWDNK 21.5" 1920x1080 5ms DVI-D VGA LED Black Monitor
Quicklinx: 88Q2WS00 Mfr#: E2250SWDNK
This model is characterized by the display technology with LED backlights, a top performance and a timelessly classic, black design. Due to high contrast and brightness values as well as a quick response time, the monitor renders even the fastest movie sequences fluently and razor-sharp. At its slimmest region, this elegant display, which sports hairline textures on the rear side as well as the base, is just 1.6 cm deep. Thanks to numerous features it is recommended for both office and home.
  • Three-Year Warranty
    AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge. Read the complete AOC warranty statement for more information.
AOC Value E2250SWDNK - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Voltage
Glossy black
51.118 cm x 19 cm x 37.995 cm
3.28 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, GOST, DDC-1, DDC-2B, CB, FCC, DDC/CI, RoHS, ISO 9241-307
3-year warranty
Display Type
Diagonal Size
21.5"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148 MHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
WLED
Power off timer, Eco-Mode, i-Menu, e-Saver technology, Screen+
Glossy black
3.28 kg
VGA , DVI-D
Mechanical
Display Position Adjustments
Tilt
Tilt Angle
-4/+17
VESA Mounting Interface
75 x 75 mm
1 x VGA cable
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
21 Watt
Power Consumption Stand by / Sleep
0.5 Watt
0.3 Watt
Power Consumption Sleep
0.2 Watt
Included Software
Screen+, I-Menu, e-Saver
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
88Q2 C2G 2m HDMI to DVI-D Digital Video Cable In Stock £11.38
