Although e2250Swda presents simple monitors with a focus on value, AOC has not skimped on display dynamics, with a vivid contrast ratio of 20,000,000:1 DCR ensuring clear visibility and vibrant images.
Outwardly, the 50-series monitor does not look at all cheap, with a slim and rounded design that tapers to just 18 mm at the top and sides. The back of the cabinet and top surface of the base feature a luxurious brushed texture. Control buttons are discreetly recessed underneath the shiny-edged screen bezel. Digital and analog connectors are rear-facing for direct insertion, also its speakers, more convenient for families.
Three-Year Warranty
AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge. Read the complete AOC warranty statement for more information.
- AOC e2250Swdak - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Glossy black
- 51.118 cm x 19 cm x 37.995 cm
- 4.06 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, TUV GS, GOST, DDC-2B, CB, FCC, DDC/CI, RoHS, ISO 9024-307
- 3-year warranty
- Display Type
- Diagonal Size
- 21.5"
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 76 Hz
- Horizontal Refresh Rate
- 83 kHz
- Video Bandwidth
- 148 MHz
- Horizontal Viewing Angle
- 85
- Vertical Viewing Angle
- 80
- Backlight Technology
- WLED
- Power off timer, Eco-Mode, i-Menu, e-Saver technology, Screen+
- Glossy black
- 4.06 kg
Audio
- Speakers
- DVI-D , VGA
Mechanical
- Tilt
- Tilt Angle
- -4/+17
- VESA Mounting Interface
- 75 x 75 mm
- Cables Included
- 1 x VGA cable
- Input Voltage
- Power Consumption (Typical)
- 32 Watt
- Power Consumption Stand by / Sleep
- 0.5 Watt
- 0.3 Watt
- Power Consumption Sleep
- 0.2 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £11.38 |
