Antec's TruePower Classic series sets standards for power supplies. By using a PSU that is 80 PLUS GOLD certified, operating up to 92% efficient, you can reduce your electricity bill by up to 20% when compared to many other power supplies. TP Classic's PhaseWave design is a server-class LLC design with a synchronous rectification based on a DC-DC topology. Japanese capacitors achieve unprecedented tight voltage regulation & low ripple & noise to maximize your system's performance. Antec's intelligent thermal manager fan control spins the high-quality 12 cm DBB fan optimally to cool your PSU quietly.
- Antec TruePower Classic TP-750C - power supply - 750 Watt
- Power supply - internal
- Specification Compliance
- ATX12V 2.4/ EPS12V 2.92
- 80 PLUS Certification
- 80 PLUS Gold
- 2.4 kg
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 750 Watt
- Output Current
- +5V - 20 A / 0 A , +3.3V - 20 A / 0 A , +12V1 - 35 A / 0.1 A , +12V2 - 35 A / 0 A , -12V - 0.3 A / 0 A , +5VSB - 2.5 A / 0 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 5 x 4 PIN internal power , 4 x 8 pin PCI Express power with detachable 2 pin section , 6 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
- Cooling System
- 120 mm fan
- 15 cm x 16.5 cm x 8.6 cm
- PSU Form Factor
- ATX
- Input Voltage
- AC 100-240 V
- Frequency Required
- 47 - 63 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 750 Watt
- Output Current
- Efficiency
- 92%
- 80 PLUS Gold
- Cooling System
- 120 mm fan
- Overheat protection, thermal monitoring, over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, surge & inrush protection, no load operation & brown-out protection, PhaseWave design
- UL, TUV, C-Tick, BSMI, cUL, CB, CCC, RoHS, GOST-R, Energy-Related Products (ErP) Lot 6
- 0 °C
- 40 °C
- 15 cm
- 16.5 cm
- 8.6 cm
- 2.4 kg
